FME Transformers: 2024.2
RasterBandAdder
Adds a new band to a raster feature.
- Adding an alpha band for transparency
- Altering raster structure to match other raster features
The RasterBandAdder receives raster features and adds a new band to them. A selection of interpretation types is available.
The new band will have the same raster-level properties as the input raster feature - that is, number of rows and columns, resolution, origin, and such.
One cell value must be specified, and will be used for all cells in the new band. The Nodata value for the band may be optionally set.
In this example, we will clip an RGB orthoimage to the irregular shape of a park polygon. Note the shape of the park, and that the raster to be clipped has three bands - RED8, GREEN8, and BLUE8.
Clipping without adding an alpha band
When the raster is clipped, cells that fall outside the clip boundary but are inside the rectangular bounds of the raster extent are set to zero (0) in all bands. Without an alpha band, these appear as black in the FME Data Inspector.
We want those black areas to be transparent, and so will add an alpha band prior to clipping.
Clipping with an added alpha band
The park polygon is routed into the Clipper input port of a Clipper transformer. The orthoimage is routed first into a RasterBandAdder, and then on to the Clipper’s Clippee input port.
In the parameters dialog, Interpretation Type is to Alpha8. Note that both Alpha8 and Alpha16 are available. Since the Red, Green, and Blue bands are all 8-bit, the alpha band bit depth should match.
For cell value, we enter 255 - the maximum possible value in an 8-bit band. The possible values range from 0 to 255, where 0 is fully transparent, and 255 is fully opaque. At this point, we want the entire image to be visible (fully opaque).
Once the raster with the new alpha band is clipped to the irregular park polygon, cells outside the park boundary have a value of 0 on all four bands. Because the newly added alpha band is also 0, that part of the image becomes transparent.
Cells inside the park boundary retain their original values, and the alpha values remain 255 - fully opaque.
Choosing a Raster Transformer
Working with Rasters
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster features with a band added as specified.
INVALID_FEATURE_ATTRIBUTE
Interpretation Type |
Select the desired interpretation for the added band, including data type and bit depth. |
Cell Value |
Specify the value that will be used for all cells in the added band. |
Nodata Value |
Optional: Set the Nodata value for the band. |
Search for all results about the RasterBandAdder on the FME Community.
