FME Transformers: 2024.2
RasterBandNodataRemover
Removes the existing Nodata identifier from selected bands of a raster feature. Any values previously equal to the Nodata value are considered valid data.
- Making cells containing the Nodata value valid for calculations.
- Making Nodata cells visible in a visualization tool that otherwise renders them transparently.
The RasterBandNodataRemover receives raster features, and removes the Nodata property from any selected bands. It does not alter cell values.
Cells that have the current Nodata value retain their values, and those values become valid for operations such as expression evaluation and statistical analysis.
Nodata represents an absence of data, and cells that have the Nodata value are ignored for most calculations, and are transparent when viewed in the FME Data Inspector and many other visualization tools.
If the raster does not have a Nodata property defined, it will be unaffected by this transformer.
To select specific bands, use the RasterSelector prior to the RasterBandNodataRemover.
This transformer supports raster band selection. Palettes are unaffected.
In this example, we want to remove the Nodata value from a numeric raster that contains slope values calculated from an elevation model.
Note that the source raster has one band, and its Nodata Value is zero (0). As a result, cells with no slope (value of zero) are not displayed, making flat surfaces such as water bodies transparent.
The raster feature is routed into a RasterBandNodataRemover.
The transformer has no parameters to configure.
The output raster no longer has a Nodata Value band property. Any cells that had the original Nodata value - zero (0) - still have that value, but they are now considered valid and are displayed.
- To add a Nodata property to a raster that does not have one, use the RasterBandNodataSetter.
- To change the existing Nodata value to a different value, use the RasterBandNodataSetter.
- To set a Nodata value on a palette, use the RasterPaletteNodataSetter.
Choosing a Raster Transformer
Working with Rasters
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster features with any Nodata properties removed from selected bands.
| Aliases | RasterNodataRemover |
Search for all results about the RasterBandNodataRemover on the FME Community.
