FME Transformers: 2024.2
RasterPyramider
- Preparing rasters for viewing at multiple zoom levels when tiling is not required, or if tiling has already been done.
The RasterPyramider accepts raster features, and “pyramids” them - resampling them to produce a set of output rasters at varying resolutions, appropriate for different zoom levels.
The number of rasters produced may be specified by Number of Levels, or by defining the smallest level size by number of columns and rows in cells (pixels).
Various methods are available for interpolation of pixel values during resampling.
Attributes may be added to the output tiles to record Pyramid level, original raster index, and number of levels produced.
This transformer is unaffected by raster band and/or palette selection.
In this example, we will create pyramids for an orthophoto. The source image is 1 meter resolution, at 1600 by 1000 pixels. Note the Min and Max Extents - these will remain unchanged as the image is resampled.
The raster is routed into a RasterPyramider.
In the parameters dialog, we select Number of Levels as the method, and set that number to 4.
Force Level Sizes to be Powers of Two is set to Yes - this will force raster dimensions to the commonly-used progression of powers of two - see Parameters below for more details on how this works.
Five raster features are output - the original, which is Level 0, plus four new pyramided rasters.
Pyramid Level 1
Pyramid Level 1 is the closest to the original raster, with new dimensions, 1024 by 512, according to the Powers of Two parameter.
Note that the geographic extents are the same as the original - but the pixel size (spacing) and resolution have changed.
Pyramid Level 4
At Pyramid Level 4, the geographic extents are still the same but the raster itself is much smaller at 128 by 64 pixels.
A closer look at the bridge detail clearly illustrates the results of resampling for different levels.
Note on Powers of Two
Using the Powers of Two parameter will produce raster dimensions with common and useful numbers for display purposes. However, if the source raster’s dimensions are not originally a power of two, as may often be the case, pyramiding using powers of two will produce pixels that are not square in ground units.
In this example, the source image pixels are 1 meter square (Spacing 1,1). At pyramid level 1, the spacing (pixel size in ground units) becomes 1.5625, 1.93125. The difference in the width and height of the pixel is a result of finding the nearest power of two numbers to scale vertically and horizontally - that is, interpolating 1600 x 1000 to 1024 by 512 within the same geographic extents.
- To tile and resample rasters using zoom levels and positions defined for various web mapping tile schemes, consider using the WebMapTiler.
Choosing a Raster Transformer
Working with Rasters
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Original raster features and resampled (pyramided) rasters according to the parameter selections.
Smallest Level Size or Number of Levels |
Choose a method for creating pyramids: Smallest Level Size: Specify the smallest desired pyramid dimensions and calculate appropriate interim level sizes and number of levels. Number of Levels: Specify the number of levels desired, and calculate interim sizes. |
Number of Columns (cells) in the Smallest Level |
When Smallest Level Size is selected, the smallest pyramid level will have a specified size, in cells (pixels). This is not the geographic extent. Define the number of cells (pixels) for the width of the smallest (lowest resolution) pyramid raster. Each subsequent level will increase the number of rows and columns by a factor of two, until the size of the input raster is reached. |
Number of Rows (cells) in the Smallest Level |
When Smallest Level Size is selected, the smallest pyramid level will have a specified size, in cells (pixels). This is not the geographic extent. Define the number of cells (pixels) for the height of the smallest (lowest resolution) pyramid raster. Each subsequent level will increase the number of rows and columns by a factor of two, until the size of the input raster is reached. |
Number of Levels |
If the Number of Levels is specified, then the largest pyramid level generated will have half the number of rows and columns of the input raster. Each subsequent level will decrease the number of rows and columns by a factor of two, until the specified number of levels has been generated. |
If Yes, the number of rows and columns in all generated levels will be powers of 2. When Smallest Level Size is specified, the number of rows and columns in the smallest level will actually be the smallest powers of 2 that are greater than or equal to the specified values. When Number of Levels is specified, the number of rows and columns in the largest pyramid level will be the greatest powers of 2 that are less than or equal to the number in the input raster. Note that pyramid levels will not be generated if either the number of rows or the number of columns is less than 2. |
Interpolation Type |
Cell values are interpolated in order to change the raster to the specified sizes.
Raster Index |
If a Raster Index Attribute is specified, an attribute will be added to each output feature that identifies which raster it was created from. This index is zero-based, so all pyramid levels created from the first input raster will have a value of 0, all pyramid levels created from the second input raster will have a value of 1, and so on. |
Pyramid Level |
If a Pyramid Level Attribute is specified, an attribute will be added to each output feature that identifies its level in the pyramid. The input raster is considered to be the base of the pyramid (level 0), so the largest level that is output for a given input raster will have a value of 1, the second largest will have a value of 2, and so on. |
Number of Pyramid Levels |
If a Number of Pyramid Levels Attribute is specified, an attribute will be added to each output raster indicating the number of levels in the pyramid to which it belongs |
Search for all results about the RasterPyramider on the FME Community.
