FME Transformers: 2024.2
RasterResampler
Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, by interpolating new cell values.
- Reducing raster resolution (by reducing the number of cells and increasing cell size)
- Coercing a raster to specific dimensions or cell (pixel) size for further processing purposes or to match other data
- Creating thumbnail images of rasters
The RasterResampler accepts raster features and alters the number of rows/columns and resizes cell (pixel) size according to the parameter selections. One raster feature is output for each input feature.
Output raster resolution may be specified by set dimensions (columns and rows), cell size in ground units, or percentage of original resolution.
A variety of methods are available for output cell value interpolation.
A: Original resolution
B: Desired resolution
C: Desired resolution compared to original
D: Resampled output raster
In this example, we will resample an orthophoto. The original raster is 1600 x 1000 pixels, with a cell size (Cell Spacing) of 1,1 - one meter wide by one meter high (the ground units of the projection).
The raster is routed into a RasterResampler.
In the parameters dialog, we select the Resolution Specification of Cell Spacing. This enables the X and Y Cell Spacing parameters, which are then both set to 25 - meaning 25 meters in ground units.
Interpolation Type is left as the default of Nearest Neighbor.
The output raster covers the same geographic extents as the input, but the cells are now 25 meters square and the resolution has correspondingly decreased to 64 x 40.
- To resize rasters (clipping or padding) without changing the cell size, consider using the RasterSubsetter
- To resample rasters to multiple sizes, consider using the WebMapTiler or the RasterPyramider.
- To split rasters in multiple smaller rasters without changing the cell size, consider using the RasterTiler.
- Although this transformer can be used to increase raster resolution, usually there is little benefit in doing so (with an exception being to match the resolution of other raster data for processing purposes).
Choosing a Raster Transformer
Working with Rasters
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
One resampled raster per input raster feature.
INVALID_PARAMETER_NUMBER_OF_ROWS
Resolution Specification |
Select a method for specifying output raster size. Options include:
Number of Columns (cells) |
If Resolution Specification is Rows and Columns, specify the desired raster width in cells (pixels). |
Number of Rows (cells) |
If Resolution Specification is Rows and Columns, specify the desired raster height in cells (pixels). |
X Cell Spacing |
If Resolution Specification is Cell Spacing, specify the desired cell (pixel) width in ground units. |
Y Cell Spacing |
If Resolution Specification is Cell Spacing, specify the desired cell (pixel) height in ground units. |
Percentage |
If Resolution Specification is Percentage, specify the desired percentage. This number must be greater than 0, and may be greater than or less than 100. 100 is equal to the input size. |
Interpolation Type |
Cell values are interpolated to produce various raster sizes and resolutions. Choose a method:
Search for all results about the RasterResampler on the FME Community.
