FME Transformers: 2024.2
RasterStatisticsCalculator
Calculates statistics on raster bands and adds the results as attributes.
- Inspecting and analyzing raster features
- Checking the results of other transformers such as the RasterExpressionEvaluator or RasterSingularCellValueCalculator
- Calculating statistics for use in further operations
The RasterStatisticsCalculator receives raster features and calculates selected statistics on them individually. The results are output on each raster, and may be generated for Band, Palette, or both.
Available statistics include:
- Minimum
- Maximum
- Mean
- Sum
- Range
- Standard Deviation
- Median
- Mode
Band statistics are stored as attributes, named <band>.<statisticname>.
Palette statistics are calculated on resolved palette values, and are stored as list attributes, named <band>.<palette>.<statisticname>.
For both types of attribute, <statisticname> will be one of the following: min, max, range, mean, stdev, sum, median, mode.
For multi-band rasters, any additional bands beyond Band 0 must be explicitly specified for inclusion in the parameters dialog - Statistics to Calculate table, under Band Index.
To calculate raster statistics on a group of rasters as a single entity, merge them prior to this transformer with the RasterBandCombiner or RasterMosaicker.
In this example, we will generate some statistics on an elevation raster. The source data has elevation values (in meters) stored in Band 0.
The DEM is routed into a RasterStatisticsCalculator.
In the parameters dialog, Raster Level Statistics is set to Band. By default, Band Index 0 is included in the Statistics to Calculate table, and we choose our desired statistics.
The output raster has new attributes containing the requested statistics.
Choosing a Raster Transformer
Working with Rasters
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
This transformer accepts only raster features. Palettes are supported.
Raster features with the specified calculated statistics.
Band statistics are stored as standard attributes, and Palette statistics are stored as list attributes.
INVALID_RASTER_CANNOT_CREATE_POINT_CLOUD
Raster Level Statistics |
Specifies for all bands chosen: whether to calculate statistics on band values, resolved palette values, or both. If Band is selected and a band with palette(s) is encountered, statistics will be calculated on the band’s cell values. If Palette is selected and a band with no palette is encountered, no statistics will be calculated for that band. If Band and Palette is selected, statistics will be calculated for bands without palettes, bands with palettes will calculate resolved palette values and cell values. |
Specifies which statistics to calculate for each band.
Band Index |
Bands are specified by their index number, starting at 0. Band 0 is included by default, and any additional bands must be explicitly specified for inclusion. |
Statistics |
The following statistics may be calculated:
Search for all results about the RasterStatisticsCalculator on the FME Community.
