FME Transformers: 2024.2
RasterBandMinMaxExtractor
Extracts the minimum and maximum band values, palette keys, and palette values from a raster feature, and adds them to a list attribute.
- Determining minimum and maximum values for use in expressions or further processing
- Examining value ranges prior to converting to a different interpretation type
The RasterBandMinMaxExtractor receives raster features, and extracts each raster’s minimum and maximum band values.
If the raster has palettes, the palette key and palette values are also determined. The minimum and maximum palette values are determined from the maximum possible extent of palette values, regardless of whether all values are used in the raster data itself. String palettes are evaluated alphanumerically.
The values are added to list attributes on the output raster feature. Possible list attributes include:
| Minimum Band Value | _band{}.min |
| Maximum Band Value | _band{}.max |
| Minimum Palette Key | _band{}.palette{}.keyMin |
| Maximum Palette Key | _band{}.palette{}.keyMax |
| Minimum Palette Value | _band{}.palette{}.valueMin |
| Maximum Palette Value | _band{}.palette{}.valueMax |
Any Nodata values that are present on the band are ignored in the minimum and maximum value calculations.
In this example, we will extract the minimum and maximum elevation values from a DEM raster. Note that the original raster feature has one band, containing elevation values in meters.
The raster is routed into a RasterBandMinMaxExtractor.
The transformer has no parameters to configure.
List attributes are added to the output feature, containing the minimum and maximum cell values found on the band. As the raster did not have any palettes, palette-related attributes were not created.
This shows that in this DEM, the elevations range from zero (sea level) to 1,782.
- This transformer only extracts band and palette minimum and maximum properties. To extract other band properties, use the RasterBandPropertyExtractor.
- To extract raster geometry properties, such as the number of rows and columns, use the RasterPropertyExtractor.
- To calculate additional band statistics, use the RasterStatisticsCalculator.
Choosing a Raster Transformer
Working with Rasters
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster features with list attributes added.
Search for all results about the RasterBandMinMaxExtractor on the FME Community.
