FME Transformers: 2024.2
Dissolver
- Simplifying geometry
- Combining areas for statistical analysis
The Dissolver receives features with area geometry and combines them wherever they touch or overlap. Shared edges and linear boundaries inside overlapping areas are removed from the resulting polygon, and output separately.
Input feature attributes may be optionally accumulated as a list attribute. Statistics can be calculated on numeric attributes, including sum, average, and weighted average (by area). The number of polygons dissolved to create each output area can be stored in an attribute.
Gaps and slivers that occur where adjacent areas are not perfectly identical are considered a match to dissolve if they fall within a specified tolerance.
Aggregates may be either deaggregated or rejected.
Z values are supported.
Input |
Dissolved |
Remnants |
Shared Edges |
Overlaps |
| Donut Polygons |
In this example, we have a set polygons representing zoning. They are color-coded by the Zone Category. There are multiple Zone Names within each category.
We want to combine the areas by category, generalizing the areas.
The features are routed into a Dissolver.
In the parameters dialog, Group By is set to ZoneCategory, so that each category will be evaluated for dissolving separately.
The Dissolve Count output attribute is given a name.
Areas have been dissolved according to category. Note the NumberDissolved attribute containing the count of polygons that went into the output area.
The remnants are also output.
- Unexpected results often indicate issues with the input data.
Transformer |
Use this to... |
Transformer Description |
Creates polygons from topologically correct linear features. |
Converts a linear feature to an area by connecting the end point to the start point. |
Combines overlapping and/or adjacent areas into larger contiguous areas by removing shared and interior edges. |
Calculate areas. |
Generalize areas. |
Cuts holes in area features where they fully enclose another area, creating donut polygons. |
Separates donut polygons into outer shell and hole polygons. |
Performs an area-on-area overlay (intersection of polygons) so that all input areas are intersected against each other and resultant area features are created and output. The resultant areas can accumulate attribute from any overlapping polygons. |
Performs a line-on-area overlay, either splitting lines where they intersect area boundaries or subdividing areas where split by lines. Attributes may be shared between related lines and areas (spatial join). |
Performs a point-in-polygon overlay. Points may receive containing area attributes, and areas may receive contained point attributes (spatial join). |
Areas to be dissolved.
Dissolved areas according to parameter selections.
Geometries left over after dissolving. Remnants receive an fme_remnant_type attribute with one of the following values:
- INTERIOR_LINE: The remnant is a portion of the input polygons that was either collinear with another feature or inside an overlapping region.
- UNUSED_DATA: The remnant is a feature that was not used at all in creating the output areas.
Features with geometry other than valid area geometry are output here. Features that receive a non-numeric value to calculate statistics on are also rejected.
INVALID_PARAMETER_ATTRIBUTE_SUM
INVALID_PARAMETER_ATTRIBUTE_AVERAGE
INVALID_PARAMETER_INVALID_ATTRIBUTE_WEIGHTED_AVERAGE
Group By |
The input areas may be partitioned into groups for dissolving. If this parameter is not specified, all input features are processed together. |
Complete Groups |
Tolerance |
Select or specify a Tolerance value, which is a maximum distance in 2D ground units between features or coordinates. If the separation between them is less than the Tolerance value, they are considered as matching and are snapped or otherwise processed accordingly. Automatic is recommended. A Custom Value may be entered, but must be greater than zero and greater than the Automatic value. |
Connect Z Mode |
If applicable, select a method for handling z values. When viewed in 2D (ignoring Z), a path (which may define the border of a polygon) may appear to be closed as shown in the left figure below. This same path, when viewed in 3D, may appear to be open as shown in the right figure below.
Aggregate Handling |
Choose how aggregate geometries are to be handled. Deaggregate: Decompose aggregates into their individual components. With this setting, the transformer might output more features than were given as inputs. Reject: Do not process aggregates and output them via the <Rejected> port. |
Accumulation Mode |
Specify how attributes are accumulated on areas:
Attributes to Sum |
Select any numeric attributes to calculate sums on. |
Attributes to Average |
Select any numeric attributes to calculate averages on. |
Attributes to Average, Weighted by Area |
Select any numeric attributes to calculate weighted averages on. Values are weighted according to the relative areas of the input polygons. |
Generate List |
When enabled:
Dissolve Count |
Name the attribute to contain the number of input polygons dissolved into an output polygon. |
Yes |
Search for all results about the Dissolver on the FME Community.
