FME Transformers: 2024.2
AreaCalculator
Calculates the planar or sloped area of polygon geometries and adds the results as attributes.
Retrieving area values as attributes
The AreaCalculator receives features with any type of geometry, and calculates areas as follows:
Area polygons (2D) - plane area
Area polygons with z values - plane or sloped area
Raster - plane area of raster extents
3D object - cumulative area of all surfaces
Other geometries (including point clouds) - receive an area of zero (0)
Area values are stored in a specified attribute.
Units are square ground units according to the feature's coordinate system. A multiplier may be applied to scale the values and convert to different units of measure.
Aggregates are supported.
In this example, we have a set of park polygons and want to extract the area of each feature in acres. Note that the coordinate system is UTM-83, with ground units in meters.
The features are routed into an AreaCalculator.
In the parameters dialog, Multiplier is set to the square meters to acres conversion factor, and the new attribute name _area is modified to _area_acres to remind us of the unit conversion.
The output features have a new _area_acres attribute, containing the area values.
Alternatively, the @Area() function can be used in expressions to calculate area values.
In general, features in a geographic projection (lat/long) should be reprojected to an appropriate coordinate system before calculating areas. The Reprojector or CommonLocalReprojector may be useful.
Transformer |
Use this to... |
Transformer Description |
Creates polygons from topologically correct linear features. |
Converts a linear feature to an area by connecting the end point to the start point. |
Combines overlapping and/or adjacent areas into larger contiguous areas by removing shared and interior edges. |
Calculate areas. |
Generalize areas. |
Cuts holes in area features where they fully enclose another area, creating donut polygons. |
Separates donut polygons into outer shell and hole polygons. |
Performs an area-on-area overlay (intersection of polygons) so that all input areas are intersected against each other and resultant area features are created and output. The resultant areas can accumulate attribute from any overlapping polygons. |
Performs a line-on-area overlay, either splitting lines where they intersect area boundaries or subdividing areas where split by lines. Attributes may be shared between related lines and areas (spatial join). |
Performs a point-in-polygon overlay. Points may receive containing area attributes, and areas may receive contained point attributes (spatial join). |
Features with area values as specified in parameters.
The dynamic <Rejected> port appears when a parameter is set to a non-literal value that might make processing impossible.
For example, if a numeric parameter such as Line Width, Count Start, or Decimal Places is set to an expression, attribute value, or user parameter, it is possible to pass in a non-numeric value that cannot be used. Decimal Places = Cat cannot be processed, so the feature will be output via this port.
Rejected features will have an fme_rejection_code attribute explaining the reason for rejection.
Type |
Select the type of area calculation to perform:
Raster and full 3D geometry (solid and mesh) area calculations are not affected by this choice. Raster area is the raster extents (plane area) and 3D area is the cumulative area of all 3D surfaces. |
Multiplier |
Specify a value to optionally scale the area values. Default is 1. |
Area |
Name the attribute to contain the area of the feature. |
Search for all results about the AreaCalculator on the FME Community.
