FME Transformers: 2024.2
DonutBridgeBuilder
Adds internal edges to connect donut holes to the outer shell, producing a non-donut polygon.
- Preparing donut geometries for formats that do not have donut support
The DonutBridgeBuilder receives donut polygons and connects all holes to the exterior shell with one continuous interior line. The result is a single non-donut polygon.
The connections between holes and the outer shell generally consist of duplicate segments in opposing directions (cycles).
There are no parameters to set.
Features with valid geometry of any type are output through the Output port.
Input features with faulty donut topology are unchanged and output through the Invalid port.
In this example, we have a donut polygon representing a portion of a major river. Note there are a number of holes, each one an island.
We want to store this in a format that does not support donuts, but want to keep the boundaries of the holes intact.
The feature is routed into a DonutBridgeBuilder.
This transformer has no parameters to set.
A single polygon is output, with interior edges connecting all of the holes.
Looking closer, we can see a number of connections between holes, as well as the point where the line connects to the outer shell.
- To revert to a donut polygon, use a Chopper (chopping to two-vertex lines) followed by an AreaBuilder.
Transformer |
Use this to... |
Transformer Description |
Creates polygons from topologically correct linear features. |
Converts a linear feature to an area by connecting the end point to the start point. |
Combines overlapping and/or adjacent areas into larger contiguous areas by removing shared and interior edges. |
Calculate areas. |
Generalize areas. |
Cuts holes in area features where they fully enclose another area, creating donut polygons. |
Separates donut polygons into outer shell and hole polygons. |
Performs an area-on-area overlay (intersection of polygons) so that all input areas are intersected against each other and resultant area features are created and output. The resultant areas can accumulate attribute from any overlapping polygons. |
Performs a line-on-area overlay, either splitting lines where they intersect area boundaries or subdividing areas where split by lines. Attributes may be shared between related lines and areas (spatial join). |
Performs a point-in-polygon overlay. Points may receive containing area attributes, and areas may receive contained point attributes (spatial join). |
Features with donut geometry.
Features with donut geometry converted to polygons, as well as any other features with valid geometry of any type.
Features with invalid donut geometry.
Search for all results about the DonutBridgeBuilder on the FME Community.
