FME Transformers: 2024.2
HoleCounter
Retrieves the number of holes in donut polygons, storing the result as an attribute.
- Making the number of holes accessible as an attribute value
The HoleCounter receives features with donut polygon geometry and retrieves the number of holes (inner boundaries) from the geometry properties of each polygon. The total per donut is stored as an attribute value.
Geometry without holes, including non-donut areas and all other types of geometry, receive a Hole Count value of zero (0).
In this example, we have a dataset of lakes and want to know the number of islands in each one.
Note that the number of holes in a donut polygon is stored as a geometry property, but is not readily accessible.
The features are routed into a HoleCounter.
In the parameters dialog, the default name is kept for the Hole Count attribute.
The number of holes is added as an attribute value.
Non-donut polygons receive a count of zero (0).
Transformer |
Use this to... |
Transformer Description |
Creates polygons from topologically correct linear features. |
Converts a linear feature to an area by connecting the end point to the start point. |
Combines overlapping and/or adjacent areas into larger contiguous areas by removing shared and interior edges. |
Calculate areas. |
Generalize areas. |
Cuts holes in area features where they fully enclose another area, creating donut polygons. |
Separates donut polygons into outer shell and hole polygons. |
Performs an area-on-area overlay (intersection of polygons) so that all input areas are intersected against each other and resultant area features are created and output. The resultant areas can accumulate attribute from any overlapping polygons. |
Performs a line-on-area overlay, either splitting lines where they intersect area boundaries or subdividing areas where split by lines. Attributes may be shared between related lines and areas (spatial join). |
Performs a point-in-polygon overlay. Points may receive containing area attributes, and areas may receive contained point attributes (spatial join). |
Features with donut polygon geometry. Other valid geometry is accepted, but receives a count of zero (0).
Features with the number of holes added as an attribute.
Hole Count |
Name the attribute to contain the number of holes in the feature. |
Search for all results about the HoleCounter on the FME Community.
