RasterPropertyExtractor
Extracts the geometry properties of a raster feature and exposes them as attributes.
- Extracting basic information about a raster feature, such as geographic extents and origin point, cell spacing, number of bands, and more.
The RasterPropertyExtractor receives raster features, and extracts basic information about their geometry. The results are added as attributes, and output with the original feature.
The transformer has no parameters.
Property attributes include:
_num_bands
_num_rows
_num_columns
_spacing_x
_spacing_y
_origin_x
_origin_y
_rotation_x
_rotation_y
_min_x
_min_y
_max_x
_max_y
_cell_origin_x
_cell_origin_y
_upper_left_x
_upper_left_y
_upper_right_x
_upper_right_y
_lower_right_x
_lower_right_y
_lower_left_x_lower_left_y
In this example, we will extract the geometry properties of an orthoimage. Note that the source raster feature has 13 typical attributes. Some geometry properties can be seen in the Feature Information window of the FME Data Inspector (under IFMERaster), but are not exposed in a usable attribute form.
The raster is routed into a RasterPropertyExtractor.
There are no parameter settings in this transformer. The raster is output, with new attributes exposed containing properties.
- This transformer extracts only raster geometry properties. To extract band and palette properties, such as band names, interpretation types, and palette information, use the RasterBandPropertyExtractor.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
| RasterBandNodataRemover | Removes the existing Nodata identifier from selected bands of a raster feature. Any values previously equal to the Nodata value are considered valid data. |
| RasterBandNodataSetter | Sets a new Nodata value on selected bands of a raster feature. |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
| PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
This transformer accepts only raster features. Palettes are supported.
Raster features with attributes containing geometry properties.
Note: Feature order may change in relation to other output ports. Feature order per port is maintained.
Dialog Options - Tables
| Aliases | RasterPropertiesExtractor |
Search for all results about the RasterPropertyExtractor on the FME Community.
