CsmapReprojector
Reprojects feature coordinates from one coordinate system to another using the CS-MAP library.
- Reprojecting features when explicitly using the CS-Map library is desired
- Reprojecting coordinates with Z values (except raster)
- Performing reprojections with finer control than the Reprojector or inherent reprojections provide
The CsmapReprojector receives vector, raster, or point cloud features and reprojects their coordinates from one coordinate system to another, using the CS-Map library.
The CS-Map library is FME’s default library, and so is generally used for most transformations. Using this transformer explicitly ensures that this library is used, and also provides options for handing Z (vertical) values.
The Source Coordinate System may be either read from the input feature or specified explicitly, and the Destination Coordinate System must be specified. Both may be set by selecting from the Coordinate System Gallery or by name via an attribute value or user parameter.
Dynamic Coordinate Systems
Features may be reprojected to a dynamic Destination Coordinate System - that is, a local coordinate system that is created specifically for each individual feature. This is often used for tasks such as taking measurements or creating geometry in meters or other ground units, on data with geographic (latitude and longitude) coordinates.
There are two types available:
- _AZMEA_ (Dynamic Reprojection Equal Area) - Better for preserving area accuracy
- _AZMED_ (Dynamic Reprojection Equal Distance) - Better for preserving distance accuracy
In either case, the input feature is reprojected to a local coordinate system centered on its bounding box. Though all the output features will be centered on a common origin (with the exception of features located very near the poles) and appear stacked on top of each other, each one retains the specifics of its reprojection (and so original position), and can be safely reprojected back into a projected or geographic coordinate system.
Note that Z values are not considered, so areas or distances are best preserved for geometry at an ellipsoid height of 0 meters.
Note: To calculate and reproject to a single AZMED or AZMEA coordinate system that encompasses all input features, consider using the CommonLocalReprojector.
Geographic Transformations
Geographic Transformations control how coordinates are converted between different datums.
The default Transformation is <Auto> (or blank), which will look for an appropriate transformation between datums, if one is needed.
If an explicitly selected pair of coordinate systems has one or more geographic transformations available, they will be provided for explicit selection.
If set to <None>, the NULL_FME transformation will be used which does not alter the value of any coordinates.
Rasters
Additional parameters are available for raster features, specifying how the reprojected cells are to be interpolated.
This transformer is not affected by raster band and palette selection.
In this example, we have a shapefile of transit lines, projected in the coordinate system UTM83-10 - UTM Zone 10, NAD83 (North American Datum 1983).
We want to reproject them into an older datum - NAD27.
The features are routed into a CsmapReprojector.
In the parameters dialog, both the Source and Destination Coordinate Systems are explicitly defined.
Though we could leave the Source Coordinate System as <Read from feature>, explicitly defining both of them gives us access to the available Transformations for that combination of coordinate systems. There are two, and we select the Canadian one for this dataset. Note that the direction is Reversed since we are going from the newer datum to the older one.
If we had previously set a preference in FME Options > Coordinate Systems > Implicit Transformations to either Canada Only or USA Only, the <Auto> Transformation option would use that setting.
The data is 2D, so Vertical Handling is not enabled.
The output features are reprojected to UTM27-10.
Examining both the input (red) and output (blue) features overlaid in the FME Data Inspector (with the Background Map OFF), we can see the results of the datum shift, based on the Canadian NTv2 grid shift file.
- FME also has a Workspace Parameter, Reprojection Engine, that may be set to either FME (CS-Map) or Esri. This transformer will override this parameter setting.
- The Reprojector provides similar functionality, and will use the default library (CS-Map or Esri) set in FME. It does not handle z values.
- To reproject coordinates stored as attribute values, consider using the CsmapAttributeReprojector.
Coordinate System Support
Library |
FME (default) or Esri |
Library (External Links) |
Sweden |
Sweden |
Switzerland |
Features reprojected as specified in parameters.
Source Coordinate System |
Specify the coordinate system of the incoming features. The default is <Read from feature>, which reads the features’ existing coordinate system(s). Coordinate systems may also be explicitly selected from the FME Coordinate System Gallery, or provided by name via an attribute value or user parameter. If <Read from feature> is used and an input feature has no coordinate system assigned, the Destination Coordinate System is assigned to it and no reprojection is performed. |
Specify the coordinate system to be reprojected to. Coordinate systems may be selected from the FME Coordinate System Gallery, or provided by name via an attribute value or user parameter. |
Transformation |
Select a method for applying a geographic transformation if one is needed to move between different datums:
Note: <Auto> and <None> are GUI only values. Use the alternative blank string and NULL_FME respectively when passing in as an attribute. |
Vertical Handling |
If Vertical Coordinate Systems is enabled, select a method for handling Z values:
Note: Rasters can only be reprojected in 2D. |
Geoid Height Grid |
If Vertical Handling includes an Orthometric height, specify the Geoid height grid file to be applied to the Z values. FME supports the following vertical grid formats:
The CsmapReprojector can apply grids in any of these formats via a .gdc file, which is a text file that list one or more grid files in the formats listed above. Grids will be tried in order until one is found that provides coverage for the point being transformed. Grid files may be listed with absolute paths, or by paths relative to the .gdc file. Example .gdc file contents for a grid file in the same folder as the .gdc: # comments start with '#' ./CGG2000.byn Some of the .gdc files shipped with FME reference grid files that are not included in the Desktop installer. Download additional Reprojection Grid Files at FME Downloads. See Vertical Grids for more information. |
Interpolation Type |
Select a method for interpolating reprojected cell values:
Cell Size |
Select a method for resizing cells:
Tolerance (cells) |
Sets the tolerance, in cells, for approximating reprojected cell locations. Using the default value of 0.0, every cell will be reprojected. If a value greater than 0.0 is specified, some cell locations will be approximated. The difference between an approximated cell location and the true cell location should be at most the tolerance value. For example, if a value of 0.5 is specified, each approximated cell location should be maximum one-half of a pixel away from its true location. Increasing the Tolerance value may improve performance. |
Dialog Options - Tables
Dependencies | Some reprojections may require additional grid files. |
Aliases | |
History |
Search for all results about the CsmapReprojector on the FME Community.
