CommonLocalReprojector
Reprojects one or more features to a local coordinate system centered on the bounding box containing all features.
Jump to Configuration
  • Reprojecting multiple features into the same local coordinate system
The CommonLocalReprojector receives features and calculates their cumulative bounding box, then reprojects the features to a local coordinate system, centered on that box, with ground units in meters. The center of the data is used as the origin point to minimize and equalize distortion in all directions.
The Projection Type may be either Equidistant (AZMED) or Equal Area (ASMEA).
Reprojector vs. CommonLocalReprojector
The Reprojector can also reproject features to local coordinate systems, however, each feature is handled individually and receives its own coordinate system based on its bounding box. An example using neighborhood polygons is shown below (A). Each feature’s origin is at its center, and so they appear stacked on top of each other.
The CommonLocalReprojector creates a single local coordinate system that spans all of the input features, and applies it to all of them (B).
Z Values
Height is not considered so areas or distances are best preserved for geometry at an ellipsoid height of 0 meters. Despite height not affecting the coordinate system that will be generated, Z values may undergo a unit shift or geocentric to ellipsoid height conversion if a Vertical Handling mode of Heights are relative to the ellipsoid or geocentric is chosen.
  • Rasters may only be reprojected in 2D (that is, with Vertical Handling set to Ignore heights and leave them unchanged).
Dialog Options - Tables
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases
History
Search for all results about the CommonLocalReprojector on the FME Community.
