CsmapAttributeReprojector
Reprojects coordinates stored as attributes from one coordinate system to another using the CS-MAP library.
Jump to Configuration
- Reprojecting coordinates stored as attributes when explicitly using the CS-Map library is desired
- Reprojecting coordinates stored as attributes with Z values
- Performing reprojections with finer control than the AttributeReprojector transformer provides
The CsmapAttributeReprojector accepts any feature. The user specifies attributes containing X, Y, and optionally Z coordinates, and supplies both the Source and Destination Coordinate Systems.
The transformer reprojects the coordinates according to these selections, using the CS-Map library, and updates the X, Y, and Z Attributes to the new values. The original values are overwritten.
This transformer does not alter the feature’s geometry – only the values of the selected X, Y, and Z Attributes (if they contain coordinate values) are changed.
Accurate results depend on the user’s correct selection of the source coordinate system.
The CS-Map library is FME’s default library, and so is generally used for most transformations. Using this transformer explicitly ensures that this library is used, and also provides options for handing Z (vertical) values.
Dynamic Coordinate Systems
Features may be reprojected to a dynamic Destination Coordinate System - that is, a local coordinate system that is created specifically for each individual feature. This is often used for tasks such as taking measurements or creating geometry in meters or other ground units, on data with geographic (latitude and longitude) coordinates.
There are two types available:
- _AZMEA_ (Dynamic Reprojection Equal Area) - Better for preserving area accuracy
- _AZMED_ (Dynamic Reprojection Equal Distance) - Better for preserving distance accuracy
In either case, the input feature is reprojected to a local coordinate system centered on its bounding box. Though all the output features will be centered on a common origin (with the exception of features located very near the poles) and appear stacked on top of each other, each one retains the specifics of its reprojection (and so original position), and can be safely reprojected back into a projected or geographic coordinate system.
Note that Z values are not considered, so areas or distances are best preserved for geometry at an ellipsoid height of 0 meters.
Note: To calculate and reproject to a single AZMED or AZMEA coordinate system that encompasses all input features, consider using the CommonLocalReprojector.
Geographic Transformations
Geographic Transformations control how coordinates are converted between different datums.
The default Transformation is <Auto> (or blank), which will look for an appropriate transformation between datums, if one is needed.
If an explicitly selected pair of coordinate systems has one or more geographic transformations available, they will be provided for explicit selection.
If set to <None>, the NULL_FME transformation will be used which does not alter the value of any coordinates.
Example: Adding an alternate coordinate system to a CSV dataset
In this example, we have a CSV file containing Community Gardens, along with their address and latitude/longitude coordinates. The features have no geometry - the coordinates are stored as attribute values.
We want to add a second of coordinates, also as attributes, in an appropriate UTM coordinate system.
This will take two steps - first, the features are routed into an AttributeManager to create a copy of the coordinates, and then to a CsmapAttributeReprojector to reproject them.
In the parameters dialog of the AttributeManager, we add the two new attributes X_COORD and Y_COORD, and copy the values from LONGITUDE and LATITUDE.
In the parameters dialog of the CsmapAttributeReprojector, we set the Source and Destination Coordinate Systems to LL84 and UTM83-10, respectively. Transformation is left as default, <Auto>.
As the data is 2D, Vertical Handling is not enabled.
The X Attribute and Y Attribute are mapped to the attributes we just added with the AttributeManager.
The output features still have no geometry, and now contain a second set of reprojected coordinates, for UTM Zone 10 NAD83.
- FME also has a Workspace Parameter, Reprojection Engine, that may be set to either FME (CS-Map) or Esri. This transformer will override this parameter setting.
- The AttributeReprojector provides similar functionality, and will use the default library (CS-Map or Esri) set in FME. It does not handle z values.
Coordinate System Support and Reprojection
CoordinateSystemDescriptionConverter
Looks up coordinate system names and definitions between FME’s internal format and common third-party and open source representations, storing the results as an attribute.
CoordinateSystemExtractor
Retrieves the name of the feature's assigned FME coordinate system into an attribute.
CoordinateSystemRemover
Removes the coordinate system from features, without modifying geometry or coordinates.
CoordinateSystemSetter
Assigns a specified coordinate system to features, without modifying geometry or coordinates.
LocalCoordinateSystemSetter
Assigns a specified local coordinate system to features, without modifying geometry or coordinates.
Reprojects x and y coordinates stored as attributes from one coordinate system to another.
FME (default) or Esri
Reprojects one or more features to a local coordinate system centered on the bounding box containing all features.
ReprojectAngleCalculator
Converts a given angle from one coordinate system to another.
ReprojectLengthCalculator
Converts a given length from one coordinate system to another.
Reprojector
Reprojects feature x and y coordinates from one coordinate system to another.
Reprojects x, y, and optionally z coordinates stored as attributes from one coordinate system to another using the CS-MAP library.
CS-Map
CsmapReprojector
Reprojects feature x, y, and optionally z coordinates from one coordinate system to another using the CS-Map library.
CS-Map
EsriReprojector
Reprojects feature coordinates from one coordinate system to another using the Esri reprojection library.
Esri
GridInQuestIIReprojector
Great Britain
Northern Ireland
Republic of Ireland
Reprojects feature coordinates from one coordinate system to another using the Grid InQuestII engine from Ordnance Survey, for use in Great Britain, Ireland, and Northern Ireland.
Grid InQuestII
GtransAttributeReprojector
Sweden
Reprojects coordinates stored as attributes from one coordinate system to another using the Gtrans reprojection engine from the National Land Survey of Sweden (Lantmäteriet).
Gtrans
GtransReprojector
Sweden
Reprojects feature coordinates from one coordinate system to another using the Gtrans reprojection engine from the National Land Survey of Sweden (Lantmäteriet).
Gtrans
PROJAttributeReprojector
Reprojects coordinates stored as attributes from one coordinate system to another using the PROJ library.
PROJ
PROJReprojector
Reprojects feature coordinates from one coordinate system to another using the PROJ library.
PROJ
ReframeReprojector
Switzerland
Reprojects feature coordinates from one coordinate system to another in Switzerland, using the Reframe library from the Federal Office of Topography (swisstopo).
REFRAME
Input
Reprojected
Features with reprojected attributes as specified in parameters. Geometry is unchanged.
Horizontal Coordinate Systems
Source Coordinate System
Specify the coordinate system of the incoming features.
Coordinate systems may be explicitly selected from the FME Coordinate System Gallery, or provided by name via an attribute value or user parameter.
Specify the coordinate system to be reprojected to.
Coordinate systems may be selected from the FME Coordinate System Gallery, or provided by name via an attribute value or user parameter.
Transformation
Select a method for applying a geographic transformation if one is needed to move between different datums:
- <Auto>: FME will select an appropriate transformation.
- Any named transformation: May be selected explicitly if available for the currently selected pair of Source and Destination Coordinate Systems.
- <None>: Use the NULL_FME transformation. Coordinate values are not altered
Note: <Auto> and <None> are GUI only values. Use the alternative blank string and NULL_FME respectively when passing in as an attribute.
Vertical Coordinate Systems
Vertical Handling
If Vertical Coordinate Systems is enabled, select a method for handling Z values:
Heights are relative to the ellipsoid(s) or geocentric
Z values will be treated as ellipsoid heights with the same units as the horizontal units (or meters, for geographic coordinate systems).
If the Source Coordinate System is geocentric, coordinates will be converted to (geographic + ellipsoid height) before being processed.
If the Destination Coordinate System is geocentric, coordinates will be converted to geocentric after being processed.
Geocentric or ellipsoid height -> Orthometric height
Z values will be converted from ellipsoid height to orthometric (sea level) height given the specified geoid height grid. Z units will be the same as the horizontal units (or meters, for geographic coordinate systems).
If the Source Coordinate System is geocentric, coordinates will be converted to (geographic + ellipsoid height) height before being processed.
Example:
[Geocentric (datum A) ->] LL + ellipsoid height (datum A) -> LL + ellipsoid height (datum B) -> LL + orthometric height (datum B)
Orthometric height -> Geocentric or ellipsoid height
Z values will be converted from orthometric (sea level) height to ellipsoid height given the specified geoid height grid. Z units will be the same as the horizontal units (or meters, for geographic coordinate systems).
Example:
LL + orthometric height (datum A) -> LL + ellipsoid height (datum A) -> LL + ellipsoid height (datum B) [-> Geocentric (datum B)]
NAD27 heights in NGVD29; NAD83 heights in NAVD88
VERTCON will be used to convert between NAD27 (NGVD29) and NAD83 (NAVD88). Z values have the same units as the horizontal units (or meters, for geographic coordinate systems).
Geoid Height Grid
If Vertical Handling includes an Orthometric height, specify the Geoid height grid file to be applied to the Z values.
FME supports the following vertical grid formats:
- Geoid96 (GEO)
- Geoid99 (bin)
- OSGM91 (txt)
- Byn (byn)
- Egm96 (grd)
The CsmapReprojector can apply grids in any of these formats via a .gdc file, which is a text file that list one or more grid files in the formats listed above. Grids will be tried in order until one is found that provides coverage for the point being transformed. Grid files may be listed with absolute paths, or by paths relative to the .gdc file.
Example .gdc file contents for a grid file in the same folder as the .gdc: # comments start with '#'
./CGG2000.byn
Some of the .gdc files shipped with FME reference grid files that are not included in the Desktop installer. Download additional Reprojection Grid Files at FME Downloads.
See Vertical Grids for more information.
Attributes
X Attribute
Provide the attribute containing the X coordinate to be reprojected.
Y Attribute
Provide the attribute containing the Y coordinate to be reprojected.
Z Attribute
If Vertical Handling is not set to Ignore Heights and leave them unchanged, provide the attribute containing the Z coordinate to be reprojected.
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies |
Some reprojections may require additional grid files.
Aliases |
History |
Search for all results about the CsmapAttributeReprojector on the FME Community.
