CoordinateSystemRemover
Removes the assigned coordinate system from features, without modifying geometry or coordinates.
Jump to Configuration
  • Removing incorrect or unnecessary coordinate system designations
  • Troubleshooting coordinate system issues
The CoordinateSystemRemover receives any feature and removes any assigned coordinate system from it. No geometry is modified, and data is not reprojected.
  • A coordinate system can be replaced without altering the geometry or coordinates by using a CoordinateSystemSetter.
  • Possession of a coordinate system definition doesn’t control whether writers create coordinate system-related metadata such as wld or prj files. These are controlled by writer parameters
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
Search for all results about the CoordinateSystemRemover on the FME Community.
