| Home | Trees | Indices | Help |
object --+
FMEGeometry --+
FMESolid
init()
FMESolid is an abstract class. It cannot be created directly.
int
FMEMultiCurve or None
None
None
None
None
None
Inherited from Inherited from |
Inherited from |
x.__init__(...) initializes x; see help(type(x)) for signature
This method returns the appearance reference within the Library associated with this solid. The front parameter controls whether this query should return the front or the back appearance reference. Both can be fetched independently. If this solid is a regular solid with no geometry instance, a FMEException will be thrown.
Returns the wireframe of the solid as a FMEMultiCurve. None is returned if a wireframe cannot be generated.
Offsets the solid by the coords specified by 'offsetPoint'.
Rotates this solid about the z-axis by the specified angle, in degrees.The rotation is performed relative to the center specified. A positive angle corresponds to a counter-clockwise rotation, when looking down onto the XY-plane.
Scale the feature by the given amounts.
This method associates an appearance within the Library with this solid. This is done by passing in the unique appearance reference for this appearance. Subsequent calls to this method on the same side, will override the previous appearance used with the new appearance passed in. An appearance reference of '0' represents the default appearance. Interpretation of the default appearance is left to the consumer of this geometry. When set at this FMESolid level, the appearance represents the default appearance to apply when the contained surfaces use the default appearance instead of a specific appearance. Contained surfaces may be found within nested solids, geometry instances that reference geometries containing surfaces, or as surfaces or multi-surfaces. The second parameter controls whether this action should take place on the front of the contained surfaces or the back. Both can be set independently. The appearanceRef should be a valid reference to a definition stored in the FMELibrary. If the reference was not found in the library, it will still attach the reference to the instance, but will throw a FMEException. This is an unhealthy situation as it represents a 'dangling reference'.
| Generated by Epydoc 3.0.1 on Thu Nov 26 19:10:16 2015 | http://epydoc.sourceforge.net |
