Module fmeobjects :: Class FMESimpleSolid
[hide private]
[frames] | no frames]
 object --+
FMEGeometry --+
       FMESolid --+
                 FMESimpleSolid
Known Subclasses:
init()
FMESimpleSolid is an abstract class. It cannot be created directly.
Instance Methods [hide private]
__init__()
x.__init__(...) initializes x; see help(type(x)) for signature
Inherited from FMESolid: getAppearanceReference, getAsWireFrame, offset, reverse, rotate2D, scale, setAppearanceReference
Inherited from FMEGeometry: __getObject__, __new__, boundingBox, boundingCube, bounds, clearMeasures, copyAttributesFromFeature, copyNameFromGeometry, copyTraitsFromGeometry, copyTraitsToFeature, deleteName, force2D, force3D, getArea, getMeasureNames, getName, getTrait, getTraitNames, getTraitNullMissingAndType, getTraitType, hasMeasures, hasName, is3D, isCollection, measureExists, removeMeasure, removeTraits, renameMeasure, setName, setTrait, setTraitNullWithType
Inherited from object: __delattr__, __format__, __getattribute__, __hash__, __reduce__, __reduce_ex__, __repr__, __setattr__, __sizeof__, __str__, __subclasshook__
Properties [hide private]
Inherited from object: __class__
Method Details [hide private]
__init__()
(Constructor)
Overrides: object.__init__
