| Home | Trees | Indices | Help |
object --+
FMEGeometry --+
FMESolid --+
FMESimpleSolid --+
FMEBRepSolid
init(surface)
FME BRepSolid class.
Create an instance of a BRepSolid geometry object.
init(outerSurface)
Creates a new BRepSolid geometry object. The surface passed in is used to define the outer surface of the bRepSolid.
outerSurface (FMESurface) - The outer surface as a surface.
Returns: FMEBRepSolid
init(brepsolid)
Create a copy of the passed in BRepSolid geometry object.
brepsolid (FMEBRepSolid) - The BRepSolid geometry object
to create a copy of.
None
| FMEBRepSolid |
FMESurface or None
| FMESurface |
int
FMESurface of a terminal type or None
None
None
Inherited from Inherited from Inherited from |
Inherited from |
x.__init__(...) initializes x; see help(type(x)) for signature
Adds an inner surface to this boundary-representation solid. If
This routine returns a copy of the given BRepSolid geometry object. If there are any errors, an exception is raised.
Returns the inner surface of this boundary-representation solid at the index specified, or returns none if the index is out of range.
Returns the outer surface of this boundary-representation solid.
Returns the number of inner surfaces in this boundary-representation solid.
Removes the last inner surface of this boundary-representation solid. If there are no inner surfaces in this solid, this method will return None.
Recursively resolves surface parts with default appearances by replacing these defaults with the inherited appearance references stored by the parent surface, if such a value exists. The nearest non-default ancestor value will be used to set the default appearances on the part.
Sets the outer surface of this boundary-representation solid as the
specified FMESurface passed in. The outer surface of a
boundary-representation solid must exist. Thus, if
| Generated by Epydoc 3.0.1 on Thu Nov 26 19:10:16 2015 | http://epydoc.sourceforge.net |
