FMEGeometry is an abstract class. It cannot be created directly.
__init__()
x.__init__(...) initializes x; see help(type(x)) for signature |
a new object with type S, a subtype of T
((float, float), (float, float))
boundingBox()
This method returns the bounding box of the geometry |
((float, float, float), (float, float, float))
boundingCube()
This method returns the bounding cube of the geometry |
tuple of FMEPoints
bounds()
Returns the bounds of the geometry. |
None
clearMeasures()
Remove all measures from the geometry. |
None
copyAttributesFromFeature(sourceFeature,
overwriteExisting,
regexp,
prefix)
Copies all the attributes from the given feature to traits on this
geometry, if they match the (optional) regular expression. |
None
None
copyTraitsFromGeometry(sourceGeometry,
overwriteExisting,
regexp,
prefix)
Copies all the traits from the given geometry that match the
None
copyTraitsToFeature(destFeature,
overwriteExisting,
regexp,
prefix)
Copies all the traits from this geometry to attributes on the given
feature, if they match the (optional) regular expression. |
bool
None
force2D()
Reduces the geometry to 2D. |
None
force3D(newZ)
This sets the geometry's dimension to 3D. |
float
tuple of strings
unicode or None
getName()
This routine retrieves the 'name' of this geometry as a unicode
string. |
bool, int, long,
float, string, unicode,
bytearray, or None
getTrait(traitName)
Retrieves the geometry trait value of the specified trait name. |
tuple of strings
getTraitNames()
Retrieve the names of the traits on this geometry. |
tuple of bool bool and
int
getTraitNullMissingAndType(traitName)
This method returns a tuple of a boolean, indicating if the trait is
null, a boolean, indicating if the trait is missing, and an integer
representing the type of the trait. |
int
bool
hasMeasures()
Check if this geometry or any sub part of this geometry has measures. |
bool
hasName()
Returns whether or not the geometry has a name. |
bool
is3D()
Returns whether or not the geometry is 3D. |
bool
isCollection()
Check if the geometry is an aggregate or multi-part collection. |
bool
measureExists(measureName)
Returns True if the specified measure exists and
False otherwise. |
None
removeMeasure(measureName)
Removes the measure with name 'measureName' if supplied, or the
default measure, if there is one. |
None
None
renameMeasure(oldMeasureName,
newMeasureName)
Renames the measure specified by oldMeasureName to the new name,
specified by newMeasureName. |
None
setName(name)
Sets the geometry's name with a unicode string. |
None
setTrait(traitName,
traitValue)
Sets a geometry trait with the specified value. |
None
setTraitNullWithType(traitName,
traitType)
This method supplies a null trait value with a type to the geometry. |
Inherited from object:
__delattr__,
__format__,
__getattribute__,
__hash__,
__reduce__,
__reduce_ex__,
__repr__,
__setattr__,
__sizeof__,
__str__,
__subclasshook__
