| Home | Trees | Indices | Help |
object --+
FMEGeometry --+
FMESurface --+
FMECompositeSurface
init(MultipleInvocations)
Create an instance of a Composite Surface geometry object.
init()
Default FMECompositeSurface constructor.
Returns: FMECompositeSurface
init(compositeSurface)
Create a copy of the passed in Composite Surface geometry object.
compositeSurface FMECompositeSurface - The Composite Surface
geometry object to create a copy of.
None
FMESurface of a terminal type or None
int
None
| FMESimpleSurfaceIterator |
Inherited from Inherited from Inherited from |
Inherited from |
x.__init__(...) initializes x; see help(type(x)) for signature
iter(x)
This appends the surface to the composite surface. If
This method returns the surface at the given index.
This returns the number of surfaces that make up this composite surface.
This removes and returns the last surface of the composite surface. If
there are no surfaces in the composite surface, it will return
Recursively resolves surface parts with default appearances by replacing these defaults with the inherited appearance references stored by the parent surface, if such a value exists. The nearest non-default ancestor value will be used to set the default appearances on the part.
This creates a simple surface iterator.
| Generated by Epydoc 3.0.1 on Thu Nov 26 19:10:16 2015 | http://epydoc.sourceforge.net |
