Create an instance of a Mesh geometry object.
Default FMEMesh constructor.
Create a copy of the passed in Mesh geometry object.
__init__(MultipleInvocations)
x.__init__(...) initializes x; see help(type(x)) for signature |
bool
addMeshPart(appearanceReference,
vertexIndices,
vertexNormalIndices,
textureCoordinateIndices)
This routine adds a new mesh part to the mesh. |
bool
addMeshPartExtended(hasAFront,
hasABack,
frontAppRef,
backAppRef,
vertexIndices,
frontTextCoordIndices,
backTextCoordIndices)
This routine extends the functionality of addMeshPart(), allowing double-sided mesh parts to
be added. |
None
appendMesh(otherMesh)
Appends a mesh passed in to the mesh, by appending the vertices,
vertex normals and texture coordinates and then by appending mesh
parts with updated indices. |
None
None
appendVertex(x,
y,
z)
Appends the point to the end of the vertex list. |
None
None
None
appendVertices(points)
Appends the vertices to the end of the vertex list. |
FMECompositeSurface or None
FMEMultiSurface or None
tuple of float or None
list of tuple s of float s
getTextureCoordinates()
Retrieves the texture coordinate list with texture coordinates in the
same index position as referenced by the faces. |
list of list s of float s
getVertexAt(index)
Retrieve the vertex, in global coordinates (i.e., the transformation
matrix is applied, if it exists), at the specified index. |
getVertexNormalAt(index)
Retrieve the vertex normal, in global coordinates (i.e., the
transformation matrix is applied, if it exists), at the specified
index. |
getVertexNormals()
Retrieves the vertex normal list with vertex normals, in global
coordinates (i.e., the transformation matrix is applied, if it
exists), in the same index position as referenced by the faces. |
getVertices()
Retrieves the vertex list with vertices, in global coordinates (i.e.,
the transformation matrix is applied, if it exists), in the same
bool
bool
bool
bool
bool
int
maxEdgeNumber()
Returns the maximum number of edges the mesh can contain. |
int
int
numVertexNormals()
Returns the number of vertex normals that are contained in this mesh. |
int
numVertices()
Returns the number of vertices that are contained in this mesh. |
None
optimizeVertexPool()
Optimizes the mesh by removing all duplicate and unreferenced
vertices, vertex normals, and texture coordinates. |
None
removeDegenerateTriangleMeshParts()
Removes this mesh's transformation matrix. |
None
removeTransformationMatrix()
bool
None
setTransformationMatrix(matrix)
Sets this mesh's transformation matrix, replacing the existing matrix
if it exists. |
Inherited from FMESimpleSurface :
numParts
Inherited from FMESurface :
deleteSide ,
getAppearanceReference ,
getAsWireFrame ,
isInPlane ,
isOriented ,
isPlanar ,
offset ,
orient ,
reorient ,
reverse ,
rotate2D ,
scale ,
setAppearanceReference ,
sideExists
Inherited from FMEGeometry :
__getObject__ ,
__new__ ,
boundingBox ,
boundingCube ,
bounds ,
clearMeasures ,
copyAttributesFromFeature ,
copyNameFromGeometry ,
copyTraitsFromGeometry ,
copyTraitsToFeature ,
deleteName ,
force2D ,
force3D ,
getArea ,
getMeasureNames ,
getName ,
getTrait ,
getTraitNames ,
getTraitNullMissingAndType ,
getTraitType ,
hasMeasures ,
hasName ,
is3D ,
isCollection ,
measureExists ,
removeMeasure ,
removeTraits ,
renameMeasure ,
setName ,
setTrait ,
setTraitNullWithType
Inherited from object :
__delattr__ ,
__format__ ,
__getattribute__ ,
__hash__ ,
__reduce__ ,
__reduce_ex__ ,
__repr__ ,
__setattr__ ,
__sizeof__ ,
__str__ ,
__subclasshook__
