Module fmeobjects :: Class FMEPoint
[hide private]
[frames] | no frames]
Class FMEPoint
 object --+
FMEGeometry --+
             FMEPoint
init(MultipleInvocations)
FME Point class.
Create an instance of a Point geometry object.
init()
Default FMEPoint constructor.
Returns: FMEPoint
init(x,y,z)
Creates a point with the given xyz coordinates.
Returns: FMEPoint
init(point)
Create a copy of the passed in Point geometry object.
Returns: FMEPoint
Instance Methods [hide private]
__init__(MultipleInvocations)
x.__init__(...) initializes x; see help(type(x)) for signature
bool
equalCoordinate(point, checkZ)
Returns True if the two points have the identical coordinate.
bool
equals(point)
Returns True if the two points have the identical coordinate and measures.
float
getMeasureValue(measureName)
Returns the value of the default measure, or the measure named by 'measureName'.
tuple of floats
getXYZ()
Get the coordinate value.
None
offset(offsetPoint)
Offsets the geometry by the coords specified by offsetPoint.
None
removeMeasure(measureName)
Remove the specified measure.
None
reset(point)
Set the coordinate and measure values to the values in the given point.
None
rotate2D(center, angle)
Rotates the point.
None
scale(xScale, yScale, zScale)
zScale is ignored if geometry is 2D.
None
setMeasure(measureValue, measureName)
Sets the value of the default measure, or creates the default measure if it doesn't exist.
None
setX(newX)
Set the x coordinate value.
None
setXYZ(newX, newY, newZ)
Set the coordinate value.
None
setXYZAsTuple(point)
Set the coordinate value as a tuple.
None
setY(newY)
Set the y coordinate value.
None
setZ(newZ)
Set the z coordinate value.
Inherited from FMEGeometry: __getObject__, __new__, boundingBox, boundingCube, bounds, clearMeasures, copyAttributesFromFeature, copyNameFromGeometry, copyTraitsFromGeometry, copyTraitsToFeature, deleteName, force2D, force3D, getArea, getMeasureNames, getName, getTrait, getTraitNames, getTraitNullMissingAndType, getTraitType, hasMeasures, hasName, is3D, isCollection, measureExists, removeTraits, renameMeasure, setName, setTrait, setTraitNullWithType
Inherited from object: __delattr__, __format__, __getattribute__, __hash__, __reduce__, __reduce_ex__, __repr__, __setattr__, __sizeof__, __str__, __subclasshook__
Properties [hide private]
Inherited from object: __class__
Method Details [hide private]
(Constructor)
Overrides: object.__init__
Returns True if the two points have the identical coordinate. Z are checked only if checkZ is True Measures are not compared.
Parameters:
  • point (FMEPoint) - The point to compare to.
  • checkZ (bool) - If set to True, z coordinate values will be checked.
Returns: bool
True if the two points have identical coordinates, False otherwise.
equals(point)
Parameters:
  • point (FMEPoint) - The other point to compare to.
Returns: bool
True if the two points have identical coordinate and measures, False otherwise.
Parameters:
  • measureName (string) - (Optional) The name of the measure whose value is to be returned.
Returns: float
The value of the default measure, or the measure named by 'measureName'.
Raises:
  • FMEException - An exception is raised if an error occurred.
getXYZ()
Get the coordinate value. 0.0 is returned for the z value if the point is 2D.
Returns: tuple of floats
The coordinate value of the point.
offset(offsetPoint)
Parameters:
  • offsetPoint (FMEPoint) - The offset point.
Returns: None
Raises:
Remove the specified measure. If 'measureName' is not supplied, remove the the default measure.
Parameters:
  • measureName (string) - (Optional) The name of the measure to be removed.
Returns: None
Overrides: FMEGeometry.removeMeasure
reset(point)
Set the coordinate and measure values to the values in the given point. The point is forced to 3D if necessary. All existing measures are lost.
Parameters:
  • point (FMEPoint) - The point to reset the coordinate and measure values to.
Returns: None
Rotates the point.
Parameters:
  • center (FMEPoint) - The center point.
  • angle (float) - The to rotate by. The angle is counter-clockwise up from the horizontal, and measured in degrees.
Returns: None
Raises:
Parameters:
  • xScale (float) - The value to scale x by.
  • yScale (float) - The value to scale y by.
  • zScale (float) - (Optional) The value to scale z by.
Returns: None
Raises:
Sets the value of the default measure, or creates the default measure if it doesn't exist. If a measureName is supplied, this method sets the value of the named measure, or creates the measure if it doesn't exist.
Parameters:
  • measureValue (float) - The value of the measure
  • measureName (string) - (Optional) The name of the measure whose value is to be set, or created.
Returns: None
setX(newX)
Parameters:
  • newX (float) - The new X value.
Returns: None
Set the coordinate value. The point is forced to 3D if necessary.
Parameters:
  • newX (float) - The new x value.
  • newY (float) - The new y value.
  • newZ (float) - (Optional) The new z value.
Returns: None
Set the coordinate value as a tuple. The point is forced to 3D if necessary.
Parameters:
  • point (tuple of floats) - The tuple to set the point to.
Returns: None
setY(newY)
Parameters:
Returns: None
setZ(newZ)
Parameters:
  • newZ (float) - The new z value.
Returns: None
