| Home | Trees | Indices | Help |
object --+
FMEGeometry --+
FMEMultiPoint
init(MultipleInvocations)
Create an instance of a Multi-Point geometry object.
init()
Default FMEMultiPoint constructor.
Returns: FMEMultiPoint
init(multiPoint)
Create a copy of the passed in Multi-Point geometry object.
multiPoint FMEMultiPoint - The Multi-Point geometry
object to create a copy of.
None
None
FMEPoint or
None
int
None
FMEPoint or
None
None
None
Inherited from Inherited from |
Inherited from |
x.__init__(...) initializes x; see help(type(x)) for signature
This appends the point to the multi point. If
This appends the multi point passed in to the multi point. If None is passed in, nothing will be appended.
This method returns the point at the given index.
This returns the number of points that make up this multi point.
Offsets the geometry by the coords specified by offsetPoint.
This removes and returns the last point of the multi point. If there
are no points in the multi point, it will return
The angle is CCW up from the horizontal and is measured in degrees.
Applies a scale factor to the multi point. The zscale is ignored if geometry is 2D.
| Generated by Epydoc 3.0.1 on Thu Nov 26 19:10:16 2015 | http://epydoc.sourceforge.net |
