| Home | Trees | Indices | Help |
object --+
FMEGeometry --+
FMEMultiCurve
init(MultipleInvocations)
Create an instance of a Multi-Curve geometry object.
init()
Default FMEMultiCurve constructor.
Returns: FMEMultiCurve
init(multiCurve)
Create a copy of the passed in Multi-Curve geometry object.
multiCurve FMEMultiCurve - The Multi-Curve geometry
object to create a copy of.
None
None
FMECurve of
a terminal type or None
int
None
FMECurve of
None
None
Inherited from Inherited from |
Inherited from |
x.__init__(...) initializes x; see help(type(x)) for signature
This appends the curve to the multi curve. If
This appends the multi curve passed in to the multi curve. If None is passed in, nothing will be appended.
This method returns the curve at the given index.
This returns the number of curves that make up this multi curve.
Offsets the geometry by the coords specified by offsetPoint.
This removes and returns the last curve of the multi curve. If there
are no curves in the multi curve, it will return
The angle is CCW up from the horizontal and is measured in degrees.
Applies a scale factor to the multi curve. The zscale is ignored if geometry is 2D.
| Generated by Epydoc 3.0.1 on Thu Nov 26 19:10:16 2015 | http://epydoc.sourceforge.net |
