| Home | Trees | Indices | Help |
object --+
FMEGeometry --+
FMESolid --+
FMECompositeSolid
init(MultipleInvocations)
Create an instance of a Composite Solid geometry object.
init()
Default FMECompositeSolid constructor.
Returns: FMECompositeSolid
init(compositeSolid)
Create a copy of the passed in Composite Solid geometry object.
compositeSolid FMECompositeSolid - The Composite Solid
geometry object to create a copy of.
None
FMESimpleSolid or None
int
None
Inherited from Inherited from Inherited from |
Inherited from |
x.__init__(...) initializes x; see help(type(x)) for signature
Appends a simple solid to the end of this composite solid. A
Returns the solid at the index specified, or returns
Returns the number of simple solids that are contained in this composite.
Removes the last simple solid of this composite solid. If there are no
solids in this composite, this method will return
Recursively resolves parts with default appearances by replacing these defaults with the inherited appearance references stored by the parent geometry, if such a value exists. The nearest non-default ancestor value will be used to set the default appearences on the part.
| Generated by Epydoc 3.0.1 on Thu Nov 26 19:10:16 2015 | http://epydoc.sourceforge.net |
