FME Library class.
Contains shared objects used by multiple features. Appearances and
textures for all features are stored in this library.
__init__()
x.__init__(...) initializes x; see help(type(x)) for signature |
a new object with type S, a subtype of T
int
addAppearance(appearance)
This routine adds the appearance object to the Library. |
int
int
addTexture(texture)
This routine adds the Texture object to the Library. |
None
deleteAppearance(appearanceReference)
Deletes the appearance with the appearanceReference index. |
None
deleteGeometryDefinition(geometryDefinitionReference)
Deletes the Geometry Definition with the geometryDefinitionReference
index. |
None
deleteTexture(textureReference)
Deletes the Texture with the textureReference index. |
FMEAppearance or None
getAppearanceCopy(appearanceReference)
This routine returns a copy of the referenced Appearance object from
the Library. |
FMEGeometry or None
getGeometryDefinitionCopy(geometryDefinitionReference)
This routine returns a copy of the referenced Geometry Definition
object from the Library.If there is no such Geometry Definition in
the Library, None is returned. |
FMETexture or None
getTextureCopy(textureReference)
This routine returns a copy of the referenced Texture object from the
Library. |
bool
hasEntry(reference)
Returns true if the library has an object with the specified
reference number. |
int
hasType(reference)
Returns the FME_LibraryObjectType if library has an object with the
specified reference number. |
None
replaceAppearance(appearanceReference,
newAppearance)
Replaces the Appearance with a new one at index =
appearanceReference. |
None
replaceGeometryDefinition(geometryDefinitionReference,
newGeometryDefinition)
Replaces the GeometryDefinition with a new one at index =
geometryDefinitionReference. |
None
replaceTexture(textureReference,
newTexture)
Replaces the Texture with a new one at index = textureReference. |
Inherited from object:
__delattr__,
__format__,
__getattribute__,
__hash__,
__reduce__,
__reduce_ex__,
__repr__,
__setattr__,
__sizeof__,
__str__,
__subclasshook__
