FME Transformers: 2025.2
Categories
Filters and Joins
Spatial Analysis
Related Transformers
AreaOnAreaOverlayer
Bufferer
Clipper
Intersector
LineOnAreaOverlayer
LineOnLineOverlayer
NeighborFinder
PointOnAreaOverlayer
PointOnLineOverlayer
SpatialFilter
SpatialRelator
TopologyBuilder
PointOnPointOverlayer
Overlays points on points, sharing attributes.
Jump to Configuration
  • Aggregating data from multiple points in the same location
  • Combining attributes from different co-located point datasets
  • Relating text or labels to point data
The PointOnPointOverlayer compares all point features that enter through the Point input port against each other. Each point may receive attributes from all other points located within the specified tolerance distance (a spatial join). Points also receive a count of the number of matched points encountered.
Geometry is unaltered.
Aggregates/multipoint geometries can either be deaggregated before processing or rejected.
  • Note that where point geometries are expected as input, point cloud geometries are not supported.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the PointOnPointOverlayer on the FME Community.
