FME Transformers: 2025.2
Categories
Filters and Joins
Spatial Analysis
Related Transformers
AreaOnAreaOverlayer
Bufferer
Clipper
Intersector
LineOnAreaOverlayer
LineOnLineOverlayer
NeighborFinder
PointOnLineOverlayer
PointOnPointOverlayer
SpatialFilter
SpatialRelator
TopologyBuilder
PointOnAreaOverlayer
Overlays points and areas, sharing attributes.
Jump to Configuration
  • Finding which areas that points fall inside
  • Finding which and how many points are contained within areas
The PointOnAreaOverlayer compares points and polygons. Each point may receive the attributes of the area(s) it is contained in, and each containing area may receive the attributes of each point it contains.
Intersections between area features are not computed. FME considers points on the boundary of an area as “in”, and so if a point falls exactly on the line between two polygons, it will be considered "in" both areas.
Aggregates can either be deaggregated before processing or rejected.
  • If you have a lot of features to process, you can improve overlay performance by also using the Clipper transformer. The Clipper also provides different options for a point that falls exactly on a line. See the Clipper example from the FME Support Center for information on how to use less memory using the Clippers First parameter.
  • If you have a lot of Point features in particular, you can reduce memory usage of the PointOnAreaOverlayer by using the Areas First parameter.
  • Note that where Point geometries are expected as input, PointCloud geometries are not supported.
  • The PointOnAreaOverlayer does not have a tolerance option for position.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the PointOnAreaOverlayer on the FME Community.
