PointCloudReplacer
- Restoring point clouds previously extracted into an attribute by the PointCloudExtractor, often used to store point clouds as Blobs in non-spatial databases.
- Creating geometry from point clouds read with an AttributeFileReader transformer.
The PointCloudReplacer receives features of any geometry type (or no geometry) that have point clouds stored as Blob attribute of the feature, most often a result of having previously used the PointCloudExtractor to store them as Blob attributes to meet format or processing requirements.
The format of the encoded Blob point cloud must be provided. The attribute storing the Blob may be optionally removed after decoding and replacing the feature’s geometry with the point cloud. Removing the attribute reduces feature size and memory usage, and may improve performance.
In this example, we will retrieve and decode a point cloud that was previously encoded with a PointCloudExtractor and loaded to a non-spatial database.
A database reader (PostgreSQL, in this case) reads the feature from the database table, which is then routed into a PointCloudReplacer.
Examining the feature as it exits the database reader, note that it has no geometry.
The two attributes - _pointcloudblob and _pointcloudformatname - contain the encoded point cloud as a Blob, and the name of the encoding (LAZ) used for the point cloud. Both of these attributes were originally created by the PointCloudExtractor.
In the PointCloudReplacer’s parameters dialog, Format is set to read the contents of the _pointcloudformatname attribute. We could alternatively set it explicitly to LAZ, if we did not have an attribute providing that information.
Blob Attribute is set to _pointcloudblob, and Remove Attribute is set to Yes, which will remove the Blob attribute once it has been decoded and set as the feature’s geometry.
The output feature now has point cloud geometry, and the Blob attribute has been removed.
- This transformer only works with point cloud formats. Use the GeometryReplacer for vector formats or the RasterReplacer for raster formats.
Features with point clouds stored as attributes.
Features with their geometry replaced by the decoded point clouds.
Features without a valid, decodable point cloud in the specified Blob Attribute will be routed to the <Rejected> port.
INVALID_FEATURE_CANNOT_READ_BLOB
Format |
The point cloud format used to decode the Blob. May be set to an attribute value, or specified explicitly. Choices include:
Blob Attribute |
The attribute from which the blob will be read. |
Remove Attribute |
If Yes, the Blob Attribute will be removed from the output feature. |
Dialog Options - Tables
Search for all results about the PointCloudReplacer on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
