PointCloudPropertyExtractor
Extracts the geometry properties of a point cloud feature and exposes them as attributes, optionally checking for their existence, retrieving component properties, and finding minimum and maximum values. Extents may also be recalculated and updated.
Jump to Configuration
- Extracting basic information about a point cloud feature, such as geographic extents, number of points, and intensity ranges.
- Calculating and updating point cloud extents after operations such as merging, clipping, or filtering that may affect their overall dimensions.
- Accessing component information such as encoding and data type, so that further manipulation of these values can be more easily done.
The PointCloudPropertyExtractor receives point cloud features and extracts basic information about their geometry. The results are added as attributes, and output with the original feature.
A selection of Components is available, which may or may not exist on the point cloud. For each component included, you may check to see if it does exist (yes or no), retrieve its properties, and/or extract its minimum and maximum values. If Check Existence is used, and the chosen property does not exist on the point cloud feature, attributes will not be added for that component’s Properties or Min/Max values.
The number of points in the point cloud feature will always be included, as the attribute _num_points.
Available standard components include:
- x
- y
- z
- intensity
- color_red
- color_green
- color_blue
- classification
- return
- number_of_returns
- angle
- flight_line
- scan_direction
- point_source_id
- posix_time
- user_data
- gps_time
- gps_week
- flight_line_edge
- normal_x
- normal_y
- normal_z
- classification_flags
Note: The extracted attribute values reflect the state of the point cloud at the time of extraction, and may become out of date if the point cloud properties change.
Calculate and Update Extents
A point cloud’s component values are static, and so must be explicitly updated to reflect changes.
This parameter may be used to update the extents (x, y, and z) of the point cloud feature after splitting, merging, or other operations that alter the bounding dimensions of the feature. The update is performed prior to the value extraction, and so the results will reflect updated extent values.
Example: Extracting point cloud properties
In this example, we will extract selected properties from a point cloud. The source is a tile of LiDAR data in downtown Vancouver, where we can clearly see tall buildings and a stadium.
Note that the point cloud has a number of Components, and we can view limited information about those components.
The point cloud is routed into a PointCloudPropertyExtractor.
In the parameters dialog, we select which information to extract by configuring the Point Components To Extract table.
The x, y, and z components are included by default (though can be removed). We add two additional components to include - classification and color_red.
Note that for both of these additional components, we have enabled the Check Existence parameter, which will check to see if the requested component exists on the feature, and return a Yes/No answer. If the component does not exist, it will return No, and will not add any additional attributes for that component.
New attributes are added to the output feature, containing the requested components, properties, and minimum/maximum values.
Note that checking for the existence of the color_red component returned No, and so no further attributes were added for that component.
Example: Updating point cloud extents after removing bad points
In this example, we start with the same LiDAR dataset as the previous example. Note the display coloring as shown in the FME Data Inspector, which renders point clouds that do not have color components using a rainbow gradient. Blue represents the lowest points, moving through the spectrum to red at the highest points.
This point cloud is shown as predominantly blue - an indication that there may be some high, invalid points that should be removed.
Note that the Max Extents z value is 447.
Examining the tops of the tallest structures, the highest valid z values appear to be less than 200.
The point cloud is routed first into a PointCloudFilter, and then on to a PointCloudPropertyExtractor.
In the PointCloudFilter parameters dialog, one expression is created, sending all points with a z value of less than 200 to the GoodPoints output port.
In the PointCloudPropertyExtractor parameters dialog, Calculate and Update Extents is set to Yes.
Note that the x, y, and z component minimum and maximum values will also be extracted.
The output point cloud feature reflects a more even color gradient distribution.
The newly calculated maximum z value is 189.08.
- To access similar information about individual points, use the PointCloudToPointCoercer to convert the point cloud feature to points.
Point Cloud Transformers
PointCloudCombiner
Combines features into a single point cloud. Point cloud and non-point cloud geometries are supported.
PointCloudComponentAdder
Adds new components with constant values to a point cloud.
PointCloudComponentCopier
Copies selected component values onto either a new or existing component
PointCloudComponentKeeper
Keeps only specified point cloud components, discarding all others.
PointCloudComponentRemover
Removes specified components from a point cloud.
PointCloudComponentRenamer
Renames an existing component.
PointCloudComponentTypeCoercer
Alters the data type of point cloud components, and converts component values if required.
PointCloudConsumer
Reads point cloud features for testing purposes, including any accumulated point cloud operations. No additional operations are performed, and nothing is done with the features.
PointCloudCreator
Creates a point cloud of specified size and density, with default component values.
PointCloudExpressionEvaluator
Evaluates expressions on each point in a point cloud feature, including algebraic operations and conditional statements, and sets individual point cloud component values.
PointCloudExtractor
Serializes the geometry of a point cloud feature into a Blob attribute, encoding the contents according to a choice of common binary point cloud formats.
PointCloudFilter
Separates point clouds into multiple features, based on evaluating expressions including component values, and creates a separate output port for each expression defined.
PointCloudMerger
Merges point clouds by joining points where selected component values match (join key), including x, y, z, and other components. Component values are transferred between point clouds and output is filtered based on matching success and duplication.
PointCloudOnRasterComponentSetter
Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location.
PointCloudReplacer
Decodes a binary attribute containing encoded point clouds stored as Blobs, replacing the feature’s geometry with the decoded point cloud.
PointCloudSimplifier
Reduces the number of points in a point cloud by selectively keeping points based on the shape of the point cloud. The simplified and removed points are output as two discrete point clouds.
PointCloudSorter
Sorts the points within a point cloud by one or more component values.
PointCloudSplitter
Separates point clouds into multiple features based on component values, color, or first/last return.
PointCloudStatisticsCalculator
Calculates statistics on point cloud components and adds the results as attributes.
PointCloudSurfaceBuilder
Takes an input point cloud and reconstructs it into an output mesh.
PointCloudThinner
Reduces the number of points in (thins) a point cloud by keeping points at a fixed interval, a maximum number of points, or a set quantity of first or last points. Remaining points are discarded.
Converts point clouds to point or multipoint geometries, optionally retaining attribute and component values.
PointCloudTransformationApplier
Applies a point cloud’s scale, offset, or transformation matrix to it, recalculating component values and removing the transformation values.
Input
Output
Point cloud features with attributes containing component properties as specified.
Output features may also have updated extents values.
<Rejected>
General
Component Attribute Prefix
(Optional) A prefix to add to attributes related to point cloud components.
If Yes, all the points of the point cloud will be read, and the point cloud extents will be updated to their exact values.
The extents of a point cloud may change after certain operations (for example, clipping). When this happens, the extents are typically set to an approximation of the true bounds (for example, when clipping, the output point cloud bounds are equal to the intersection of the input point cloud bounds and the clipper bounds).
Point Components to Extract
This table is used to specify the components for which to extract properties, and which properties to extract for each component.
The x, y, and z components are included by default, and may be removed.
The number of points will always be extracted into the attribute _num_points.
Component
Any or all components may be requested. Component names may be entered directly or selected from the available list of standard components.
Check Existence
If enabled, the following properties will be extracted:
_<component>
(For example, _intensity) - This will be set to Yes if the component exists, and No if it does not.
Note that if a requested component does not exist, only the existence check attribute (_<component>) will be set. All other attributes will be ignored.
Retrieve Properties
_<component>_type
The type of the component. Valid types are Real64, Real32, UInt64, Int64, UInt32, Int32, UInt16, Int16, UInt8, Int8, String.
_<component>_scale
The scale factor for the component. Only set for numeric components.
_<component>_offset
The offset for the component. Only set for numeric components.
_<component>_encoding
The encoding of the component. Only set for string components.
Retrieve Min/Max
_<component>_min
The minimum value for the component in the point cloud.
_<component>_max
The maximum value for the component in the point cloud.
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies |
None |
Aliases |
History |
The is the place for demos, how-tos, articles, FAQs, and more. Get answers to your questions, learn from other users, and suggest, vote, and comment on new features.
Search for all results about the PointCloudPropertyExtractor on the .
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
