PointCloudExpressionEvaluator
- Performing calculations on individual point values within a point cloud
- Updating point cloud component values
- Adding new point cloud components
The PointCloudExpressionEvaluator receives point cloud features and evaluates defined expressions using the individual points’ component values, then outputs a point cloud feature with the calculated values applied to existing or new components.
Expressions
Expressions are defined in the right-hand column of the Component Expression(s) table. Each line in the table corresponds to one component, which may be new or existing. Component names may be selected from a list of standard components, or user-specified.
The Data Type for each component is also specified here, and may be set to automatically determine the appropriate type, or to preserve the type of an existing component. Strings are not supported.
Expressions may be as simple a constant value or simple arithmetic operation. The Arithmetic Editor is available via the Expression ellipsis (...) button to assist in the construction of expressions. Point cloud components are available in the editor.
Expressions are case-sensitive.
Expression Syntax
An expression consists of a combination of operands, operators, and parentheses.
White space may be used between the operands, operators, and parentheses as it is ignored by the expression processor.
Operators
See Math Operators for a complete list and documentation.
Means... |
| || | Or |
| && | And |
| == | Equal |
| != | Not equal |
| < | Less than |
| > | Greater than |
Operands
Operands may be any of the following:
Example(s) |
Description |
Component |
@Component(z) @Component(color_red) @Component(return) @Component(<user_component>) |
A component from an input point cloud. Note that if a component has a scale/offset, the "applied" value of the component will be used in the expression. |
Constant |
42 0 13.5 3. 6e4 7.91e+16 |
A numeric constant, either integer or floating-point. Where possible, numeric constants are interpreted as integer values; otherwise, operands will be treated as floating-point numbers. |
Attribute Value |
@Value(point_cloud_id) | The value of an attribute, using @Value() notation. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Function |
@sqrt(@Component(z)) @if(@Component(z) < 0,0,@Component(z)) |
A function whose arguments have any of the above forms for operands. Available functions include:
Note: See Math Functions for a complete list of FME math functions and documentation. Not all functions are available in all contexts. |
Private or Published Parameter |
$(User_Parameter)
Published and private parameters, including user parameters. See Creating and Modifying User Parameters. |
Types and Overflows
This transformer attempts to avoid overflows by changing data types through the course of evaluating an expression. For example, if two UInt8 values are added together, the internal computations will be performed with a UInt16 type; this ensures that no overflow will occur.
In general, performing an arithmetic operation on integer types will produce an integer type. The exception to this is division: it will always produce a floating-point result. Performing an arithmetic operation on floating-point types will always produce a floating-point type.
Note that when converting between different data types, a Bounded Cast is used. As a result, when a calculated value does not fit in the specified destination data type, the corresponding destination value will either be set to the minimum or maximum value possible in the destination data type. For example, a value of 300, if converted to an unsigned 8-bit integer component (UInt8), would become 255 (the maximum available value for that data type).
In this example, we will calculate above-ground-level (AGL) heights for a LiDAR point cloud, located on the coast, near sea level, with many tall buildings.
Note that the source feature, viewed here in the FME Data Inspector from an oblique angle in 3D, has a z component representing the elevation of the point - which is not necessarily the elevation of the ground. Points are returned above the ground when they encounter structures and vegetation.
We will overlay the point cloud on a DEM elevation raster in order to extract the ground elevations. Note that the elevations are stored in Band 0 of this single-band raster. Both datasets are in the same coordinate system and units.
The operation will take two steps. First, both the point cloud and DEM raster are routed into a PointCloudOnRasterComponentSetter to extract the ground elevations. Then the resulting point cloud feature is sent on to the PointCloudExpressionEvaluator to calculate the AGL heights.
Step 1 - Extracting Ground Elevations
In the parameters dialog of the PointCloudOnRasterComponentSetter, we set Components to Set to Custom.
The custom component is defined in the Components table, extracting values from Band 0 to a new component named Elevation. The Default Value is set to 0.
Note that the output point cloud feature has a new component - Elevation. The selected point shown here has a z value of about 97.57 meters -but the ground elevation at that location is only about 4.985 meters.
Step 2 - Calculating Height
In the parameters dialog of the PointCloudExpressionEvaluator a new Component is defined, named AGL. The Data Type is set to Auto, and an expression is constructed that subtracts the ground elevation from the point elevation.
The output point cloud feature has a new AGL component with the results of the expression evaluation.
The point selected here has a z value of 95.37 meters. Subtracting the ground elevation produces a height above ground of about 89.88 meters.
- This transformer does not support strings. To add string components, use the PointCloudComponentAdder.
- This transformer can be used to set an existing component to a constant value by setting the expression to the desired constant.
- The arithmetic editor is available from the ellipsis (...) button to assist in constructing expressions. See Arithmetic Editor for full documentation.
Point Cloud features with new or updated component values as specified in the parameters.
INVALID_FEATURE_COMPONENTS
MISSING_FEATURE_COMPONENTS
INVALID_FEATURE_MISSING_ATTRIBUTES
Component |
Specifies the component to be set by the corresponding expression. Standard component names may be selected from the drop-down menu. Custom user component names may be entered directly. Components may be either existing or new, and will either be updated or created, respectively. |
Type |
Select the type of the component in the output point cloud. Choices include:
Expression |
Define an expression to be evaluated. The Arithmetic Editor may be accessed via the ellipsis (...) button to assist in creating expressions. The result of this expression will be stored in the corresponding component on the output point cloud. |
Dialog Options - Tables
Search for all results about the PointCloudExpressionEvaluator on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
