AttributeFileReader
Reads the contents of an external text or binary file and attaches it to a feature as the value of an attribute.
- Attaching files to features
- Adding file contents to features
- Reading geometry content stored in a separate file
The AttributeFileReader receives any type of feature and adds the contents of an external file to them, as the value of a new or existing attribute.
File selection may be done explicitly or by attribute value, expression, user parameter, or conditional value.
The file may be text or binary. (Text refers to the file type, rather than the file content - it may not necessarily be plain text.) A variety of encoding choices are available for text files. Binary files should be designated as Binary (fme-binary), as the transformer is not aware of formats and will simply preserve the file contents as a Blob.
In this example, we will read a text file and add it to a raster feature as an attribute. We want to add a palette (the text file) to a numeric raster in GeoTIFF format.
The raster is first routed through a RasterBandInterpretationCoercer to meet processing requirements - the band type must be an unsigned integer to be compatible with palettes.
Next, the raster is passed to an AttributeFileReader. Note that it has one exposed attribute and consists of one numeric band, an 8-bit unsigned integer.
A text file containing the palette information has already been prepared, as shown here in Notepad.
In the parameters dialog of the AttributeFileReader, we keep the default File Contents attribute name as_file_contents, and select the Palette_color.txt file.
As this is a text file, prepared on the same computer it is being processed on, we can use the System Default (fme-system) encoding.
Examining the output from the AttributeFileReader, note that the raster now has an additional attribute, _file_contents, which contains the contents of the text file.
The last step in this workflow is to apply the palette from the new attribute with a RasterPaletteAdder.
In this example, we have both a point cloud and an orthoimage of the same area, and want to keep them together - so we will attach the image to the point cloud feature as an attribute.
Note that the point cloud has one exposed attribute.
The orthoimage is a GeoTIFF.
The point cloud is routed into an AttributeFileReader.
In the parameters dialog, we keep the default File Contents attribute name as_file_contents, and select the StadiumOrthoLowRes.tif file.
Source File Character Encoding is set to Binary (fme-binary), which will store the GeoTIFF as a Blob.
Examining the output in the FME Data Inspector, note that the point cloud has a new attribute which contains the orthoimage, still encoded in binary.
From here, the image can be decoded and used at any time with a RasterReplacer, as in the example below which would use the raster to color the points of the point cloud with a PointCloudOnRasterComponentSetter. Another subsequent use could be writing it to a Blob column in a database.
- All types of binary files are stored as Blobs, and Source File Character Encoding should be set to Binary (fme-binary) .
- The most common text encodings are Windows Latin-1 (windows-1252) and Unicode 8-bit (utf-8).
- If a text file includes special characters, the appropriate Source File Character Encoding should be selected to preserve those characters.
- Full path names can be created from existing attribute values by using the Text Editor to create an expression.
- Some transformers (such as the XMLFlattener) can read external files, and so do not need to use an AttributeFileReader first.
Features to receive files as attributes.
Features with files added as attribute values as specified in the parameters.
If an invalid filename is specified, the feature will be routed to the <Rejected> port. Rejected features will have an fme_rejection_code attribute with one of the following values:
INVALID_FILE_INACCESSIBLE
Source Filename |
The name and location of the file to be read. It may be specified explicitly or by attribute value, expression, user parameter, or conditional value. |
Source File Character Encoding |
Specify the source file's character encoding. Binary (fme-binary) includes all binary file types. |
File Contents |
Name the attribute to contain the contents of the file. New attributes will be added and existing attributes will have their values overwritten. |
Dialog Options - Tables
Search for all results about the AttributeFileReader on the FME Community.
