You are here: Reference Manual > FME Server Web Services > Notification Service > Publishers > Configuring the Publisher
                                        - In the FME Server Web User Interface, select Notifications > Publications, and click New.
 - Name: Provide a name for your Publication.
 - Protocol: Select Amazon SQS.
 - Topics To Publish To: Specify the Topics you want to publish to using the drop-down selector. To create a topic and use it right away, click +.
 - SQS Queue URL: Provide the URL of the queue.
 - AWS Access Key ID and AWS Secret Access Key: Provide your AWS security credentials.
 - Delete Message After Received: If Yes, the publisher deletes the Amazon SQS message from FME Server after it is published. If No, the publisher does not delete the message. (Instead, a corresponding subscriber process is responsible for deleting it.)
 - Visibility Timeout: The time, in seconds, beginning when the publisher starts, during which other SQS publishers cannot access the same message from the Amazon SQS queue.
 - Click OK. Your publication is now configured to receive messages from the specified queue.
Keywords
The publisher associates elements in the incoming messages with the following keywords:
| Keyword | Description |
| sqs_md5 | MD5 of the message. |
| sqs_message_id | ID of the message. |
| sqs_publisher_content | Body of the message. |
| sqs_receipt_handle | Receipt handle of the message. |
See Also
