You are here: Administrator's Guide > Performing an Installation > Distributed/Fault Tolerant Installation > Distributing Components (2-Tier)
Before installing a 2-tier distributed architecture, make sure you have:
- Reviewed Planning an FME Server Installation.
- Provided the prerequisites in Before Installation.
To perform a 2-tier installation of FME Server:
- Obtain the Installer
- Install the FME Server Core, FME Engines, and Web Application Server.
- Configure the FME Server Database on your database server.
- Request and Install a License.
- (Upgrade Only) Restore your FME Server Configuration from a Previous Installation.
- (Recommended) Update the Windows service accounts that run the FME System Services.
What's Next?
- Optimize: You can scale-up your FME Server by:
- Increasing the number of FME Engines that run when you start FME Server.
- Adding FME Engines on separate machines that are closer to your data.
For more information, see Planning for Scalability and Performance.
