You are here: Point Clouds > PointCloudThinner
PointCloudThinner
Outputs point cloud features that have fewer points than the original input features. This transformer is typically used to reduce data volume by identifying a set of points to keep and discarding the remaining points.
Thinning Type Amount Result
Every Nth Point (Interval) 5 Every 5th point of the input cloud feature will be present in the output point cloud.
Every Nth Point (Maximum Number of Points) 100 The output cloud will have a maximum of 100 points, evenly spaced throughout the input.
First N Points 100 The first 100 points from the input will be kept.
In this example, the output point cloud on the right keeps every 50th point from the source point cloud on the left:
Transformer Categories
Point Clouds
Related Transformers
The transformer can be used with PointCloudCombiner to make mosaics of large areas from smaller tiles.
Search FME Knowledge Center
Tags Keywords: point "point cloud" cloud PointCloud resample thin LiDAR sonar PointCloudSampler
