You are here: Point Clouds > PointCloudSimplifier
Outputs point cloud features that have fewer points than the original input features while maintaining the original shape. This transformer is typically used to reduce data volume by identifying a set of points to keep and discarding the remaining points.
Simplification Algorithm
Medial Axis Transform Parameters
Tuning and Noise Reduction
Advanced
Transformer Categories
Point Clouds
Search FME Knowledge Center
Tags Keywords: point "point cloud" cloud PointCloud LiDAR sonar
