You are here: Integrations > EsriReprojector
EsriReprojector
Reprojects feature coordinates from one coordinate system to another using the Esri reprojection library.
This transformer always reprojects from the source coordinate system to the destination coordinate system, tagging the features with the destination coordinate system on output. Any coordinate system set on the input features is ignored.
Dependencies
To use this transformer, you must have ArcGIS installed on the same machine as FME. The bit version, 32-bit or 64-bit, must be the same for FME and ArcGIS.
Raster Parameters
This transformer is not affected by raster band and palette selection.
Transformer Categories
Coordinates
Format Specific
Integrations
Licensing Level
This transformer is not available in FME Base Edition.
Search FME Knowledge Center
