MultipleGeometryFilter
Filters aggregate features based on the type of aggregate.
If the aggregate is set up such that each part is independent from the others, and should be interpreted as its own complete geometry, then the feature will be sent to the Contains port.
Aggregates that do not match the criteria for Contains will be sent to the NotContains port.
This transformer works only on aggregates, so features containing any other geometry type will be sent to the <Rejected> output port.
Example
It may be useful to know whether a feature contains multiple geometries when the source dataset supports the notion of multiple independent geometries per feature but the destination dataset does not.
In this case, it may be desirable to split up the feature into multiple separate features.
Transformer Categories
Transformer History
This transformer was previously named IndividualGeometriesFilter.
Search FME Knowledge Center
Tags Keywords: aggregate individual multiple many IndividualGeometriesFilter
