• FME Desktop Administrator's Guide
    • Intended Audience
    • Notices
    • Support and Resources
    • Accessing Help Files and Product Documentation
  • Getting Started and System Requirements
    • Prerequisites
    • Determining the FME License Type to Install
    • Glossary of Terms
  • Installing
    • Installing FME Desktop on Windows
    • Installing FME Desktop on Linux
    • Installing FME Desktop on Mac
  • Licensing
    • Single-Fixed Licenses
    • Floating Licenses
    • Licensing from the Linux Command Line
    • Getting Your Current Licensing Status
  • Other Common Tasks
    • Installing the Software Development Kit for FME Desktop
    • Installing Grid Shift Files
    • Using FME Desktop with Third-Party Applications
  • All Files
  • Installing a Floating License on Linux
    • Before You Begin
    • Locate the Flexera License Manager Files
    • Create a Directory for the Flexera License Manager
    • Provide the Information to Generate a Floating License
      • Obtaining the Hostname
      • Determining the Host ID
      • Determining the FME Serial Number
    • Install the Floating License
    • Configure FME Desktop to Use the Floating License
You are here: Licensing > Floating Licenses > Installing a Floating License on Linux > Provide the Information to Generate a Floating License
Safe Software requires three pieces of information to generate a floating or node-locked license:
  • hostname
  • host ID
  • FME serial number
What's Next?
