You are here: Licensing > Floating Licenses > Installing a Floating License on Linux > Provide the Information to Generate a Floating License > Determining the FME Serial Number
To get your serial number, see the confirmation e-mail you received after purchasing FME Desktop.
Visit www.safe.com/activation/floating/ and submit the Floating License Request.
Safe Software will send you a file called safe.lic that contains the key code file for the license code server.
Copy the safe.lic file into the FlexServer directory on your license server computer.
The filename must remain in lowercase text. Safe Software recommends that you do not change the filename.
