Troubleshooting Active Directory Configurations
Tips before starting:
- Start with the configuration in Recommended Configuration for Active Directory Connections.
- Ensure that SECURITY_DEBUG=true is set in the fmeCommonConfig.txt. This configuration parameter is located under the 'Security Management' heading. With this debugging flag enabled, all interactions with Active Directory are logged.
- Look in the fmeServer_* log files for messages with '(Active Directory)' or '(Single Sign-On)'. These files are located in <FMEServerDir>/Logs.
In this section
Failure to Connect to Active Directory Server (Auto-Detect)
Failure to Connect to Active Directory Server (Manual)
Failure to Connect to Active Directory Server (SSL)
Unable to Use SASL Authentication
Single Sign-On Authentication Failure (Disabled)
Single Sign-On Authentication Failure (Incorrect Mechanism)
Single Sign-On Authentication Failure (Negotiation Error)
Single Sign-On Authentication Failure (Service Account)
Single Sign-On Authentication Failure (Cross-Domain User)
