Missing Service Account
Log file message
(Active Directory) Missing service account; certain features of FME Server (including token authentication and single sign-on authentication) will not work as intended. Please refer to the SECURITY_AD_PREAUTH_USERNAME parameter in fmeServerConfig.txt for details.
Cause
A token service request was made to access the REST API, but a service account was not specified.
Resolution
To use the token service to access the REST API, ensure that a service account is specified using the SECURITY_AD_PREAUTH_USERNAME and SECURITY_AD_PREAUTH_PASSWORD configuration parameters. For more information, see Connecting to Active Directory.
Note: Specify only a service account name for the SECURITY_AD_PREAUTH_USERNAME parameter. Do not include a domain name. For example, do not specify domain_name\\user_name. Specify only user_name.
Log file message
(Single Sign-On) Pre-authenticated credentials (for a service account) were not specified in configuration, and is required by single sign-on authentication.
Cause
Single sign-on was enabled, but a service account was not specified.
Resolution
When SECURITY_AD_USE_SINGLE_SIGN_ON=true, ensure that a service account is specified using the SECURITY_AD_PREAUTH_USERNAME and SECURITY_AD_PREAUTH_PASSWORD configuration parameters. For more information, see Updating Windows Domain Configuration.
