You are here: Licensing > Floating Licenses > Troubleshooting Floating Licences > Specifying the FME Edition to Use
If your floating license service supports multiple editions of FME, you can use the flexlm_config.dat file to tell FME what edition to use.
To determine the FME editions you are licensed for, consult the safe.lic file on your license server.
To specify the FME Edition to Use
On the computer that is running FME Desktop, edit (or create) flexlm_config.dat in the <FMEDir>\licenses\ folder.
The contents should be the following two lines:
Registered Product=<FME edition name>
<Displayed name in FME>
For example:
Registered Product=smallworld
FME Desktop Smallworld Edition
<FME edition name> is case-sensitive. <Displayed name in FME> appears when you navigate to Help > About in FME Workbench or FME Data Inspector.
Possible values for FME Edition Name are:
| FME Edition Name | Displayed Name in FME |
| desktop | FME Desktop Base Edition |
| professional | FME Desktop Professional Edition |
| esri | FME Desktop ESRI Edition |
| arcgis | FME Desktop Data Interoperability Edition |
| intergraph | FME Desktop Intergraph Edition |
| oracle | FME Desktop Oracle Edition |
| db2 | FME Desktop DB2 Edition |
| sql_server | FME Desktop Microsoft SQL Server Edition |
| smallworld | FME Desktop Smallworld Edition |
| server | FME Engine |
| webmap | FME Data Server for GeoMedia WebMap |
| netezza | FME Netezza Edition |
| teradata | FME Teradata Edition |
| arcgis_server | FME FME ESRI ArcGIS Server Edition |
