Installing a Single-Fixed License
A single-fixed FME license (also known as node-locked or CRC license) enables FME to work on a single specified computer. The FME Licensing Assistant generates a unique registration key for that computer, which is used to create the license. If FME is installed on more than one computer, each computer requires its own license.
Before You Begin
Your serial number is printed on your welcome letter and your invoice. If you do not know or cannot find your serial number, please send an e-mail to codes@safe.com to request a license file.
To activate your license you will need an Internet connection.
