You are here: Licensing > Floating Licenses > Troubleshooting Floating Licences > Access to Floating License Times Out Over VPN
Access to the FlexNet floating license over a virtual private network (VPN) may time out if the network is slow. To minimize this issue, set the FLEXLM_TIMEOUT environment variable.
- Open the Windows System Properties dialog (Start > Control Panel > System > Advanced System Settings.
- On the Advanced tab, click Environment Variables.
- Under System Variables, click New.
- In the Variable name box, enter: FLEXLM_TIMEOUT
- In the Variable value box, enter: 1000000
- Click OK to close each dialog box.
