Installing FME Desktop on Linux
Updating to a Newer FME Version
If you are updating to a newer version of FME Desktop, you must first manually uninstall the earlier version. Alternatively, you can install to a different directory and have multiple versions of FME Desktop.
Make sure you back up or relocate any custom files that you have saved in your FME installation directory.
Uninstalling
To uninstall, run the uninstall.sh
script in the FME installation directory. To ensure the uninstall is complete, run this script as root.
Installing
All installation steps must be performed "as root" (via the sudo command on some distributions). FME Desktop is installed for ALL users.
The install location is /opt/fme-desktop. When complete, the installer generates a configuration file to /opt/fme-desktop/install.cfg
The following installers are available:
Platform |
Installer Name |
Debian (Ubuntu) |
fme-desktop_<release>-<build>_amd64.deb |
Fedora (RedHat, CentOS) |
fme-desktop_<release>-<build>_amd64.rpm |
Ensure that your system meets all the requirements. See Linux System Requirements.
Downloading the Installer
Download the FME Desktop Installer to your local machine. To obtain the installer, visit http://www.safe.com/support/downloads.php.
Running the Installer Using the Package Manager
To use the package manager to install FME Desktop and all dependencies, double-click on the package.
The Debian installation package does not support the Ubuntu 14.04 Unity package manager. Instead, use the command line to install.
Running the installer Using the Command Line
Run the following commands, depending on your Linux platform, and substituting <release> and <build> with the corresponding values from your installer name.
Debian package:
If gdebi is not already installed: apt-get install gdebi-core
gdebi fme-desktop_<release>-<build>_amd64.deb
Or
dpkg -i fme-desktop_<release>-<build>_amd64.deb
apt-get install -f
Fedora package:
On RedHat or CentOS, you must first configure access to the EPEL and IUS package repositories. For more information:
EPEL: https://fedoraproject.org/wiki/EPEL#How_can_I_use_these_extra_packages.3F
IUS/EPEL: http://www.rackspace.com/knowledge_center/article/install-epel-and-additional-repositories-on-centos-and-red-hat, https://iuscommunity.org/pages/Repos.html#release-packages
yum install fme-desktop_<release>-<build>_amd64.rpm
