Windows System Requirements
Supported Platforms
Note: Both 64- and 32-bit versions of the following Windows platforms are supported, except where specified.
- Windows 10
- Windows 8
- Windows 7
- Windows 2012 Server
- Windows Server 2012 R2
- Windows 2008 Server SP2 or later
Note: All 64-bit Windows editions listed above also support 32-bit FME. See Which Version? for details on differences between 32-bit and 64-bit FME.
Minimum System Specifications
System specifications will vary depending on your FME usage, including the size of your data files. However, at minimum, we recommend:
- Intel® Pentium® 4 processor
- 4 GB of RAM (8 GB on a 64-bit OS)
- 20 GB of available hard-disk space
Note: To install FME on a server for use with a thin-end client (for example, a Citrix® installation), you must use an FME floating license. To install floating licenses, you must be running a TCP/IP network.
Recommended System Specifications
Note: FME will operate well with the minimum recommended configuration; however, any application benefits from additional resources. For large processing tasks, additional memory and a fast disk can measurably improve processing time.
- Intel® Core i7 CPU
- 8 GB of RAM (16 GB on a 64-bit OS)
- 50 GB of available hard-disk space
- A Solid-State Drive (SSD)
