FME Transformers: 2026.2
Categories
Attributes
Related Transformers
AttributeCopier
AttributeCreator
AttributeKeeper
AttributeManager
AttributeRemover
AttributeRenamer
AttributeValueMapper
BulkAttributeRemover
BulkAttributeRenamer
Renames attributes by adding or removing prefixes or suffixes, or replacing text using regular expressions or character strings. This transformer is useful if you need to quickly rename all (or many) of your attributes.
Jump to Configuration
  • Rename multiple attributes to match a naming convention
  • Add prefixes or suffixes to attribute names
  • Remove prefixes or suffixes from attribute names
  • Change the case of attribute names
  • Replace a string in attribute names
The BulkAttributeRenamer lets you select either all attributes or specific ones, and then choose a renaming method. All attributes on features that enter the transformer are modified according to your selections.
If the renaming process results in an empty attribute name, that attribute will be removed - for example, removing a suffix where the suffix itself is the whole attribute name.
The values of attributes are unchanged.
  • This transformer is specifically for changes to attribute names. To change attribute values use the StringReplacer or AttributeManager transformers.
  • Use the AttributeManager to rename individual attributes, with the option of supplying a default value if the original attribute was not present.
  • Use the StringCaseChanger to change the case of attribute values (not names).
  • If Rename All attributes is chosen, unexposed format attributes may also be renamed, which may produce unexpected results. Consider using Selected Attributes and the attribute pick list for finer control.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases AttributePrefixer AttributeExpressionRenamer AttributeNameCaseChanger
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the BulkAttributeRenamer on the FME Community.
