FME Transformers: 2026.2
Categories
Attributes
Related Transformers
AttributeCopier
AttributeCreator
AttributeKeeper
AttributeManager
AttributeRemover
AttributeRenamer
AttributeValueMapper
BulkAttributeRenamer
BulkAttributeRemover
Removes all attributes with names that match a given regular expression. This transformer can be used to remove large numbers of attributes that have common naming patterns.
Jump to Configuration
  • Remove multiple attributes from features where the attribute names have something in common, such as a prefix, suffix, string, or a pattern that can be described with a regular expression.
The BulkAttributeRemover lets you enter a regular expression - which may be as simple as a specific series of characters, or as complex as you like, using Advanced Regular Expression syntax.
Any attributes with a portion of their name matching your expression are removed, and all other attributes pass through the transformer untouched.
Matches are case-sensitive.
  • Use the AttributeManager to remove selected individual attributes from a feature.
  • Use the AttributeKeeper to remove large numbers of attributes without expression matching, and keep selected individual attributes on a feature.
  • This transformer will not remove fme_ attributes - to remove them, use either the AttributeRemover or AttributeManager.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases AttributeExpressionRemover
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the BulkAttributeRemover on the FME Community.
