FME Transformers: 2025.0
TextPropertyExtractor
Retrieves text property values from text geometry, adding them to the feature as attributes.
- Preserving label strings, size, and orientation independent of geometry.
- Making text properties accessible
- Storing text properties for use elsewhere in a workspace
The TextPropertyExtractor receives features with text geometry and extracts their properties into attributes.
Extracted properties include:
- Text String
- Text Size in ground units
- Text Rotation in degrees
To exclude an attribute, leave the parameter blank and it will not be added to the output features.
Feature geometry is unchanged.
Features without valid text geometry are rejected.
In this example, we have a set of text labels without attributes, provided as a DXF file.
Note that the geometry properties have information about the label, but this is not readily accessible as attribute values.
The features are routed into a TextPropertyExtractor.
In the parameters dialog, the default attribute names are kept.
The output features have new attributes, containing the text string, size, and rotation of the labels. The text geometry remains unchanged.
- This transformer may be useful in conjunction with the TextLocationExtractor when converting labels to non-text geometry.
Creating and Modifying Point and Text Features
These transformers work with points, text, and labels in a variety of ways.
Transformer |
Use this to... |
Transformer Description |
Create one or more new features with box geometry of a specific size and position (when Geometry Object is Point or Text). |
Replace a feature’s geometry with a point at a specified location. |
Creates a single vertex to replace, be appended to, or be inserted into existing geometry. |
Create points inside features or their bounding boxes. |
Replaces feature geometry with a point located within the feature, its bounding box, or at its center of mass. |
Extract the coordinates of a calculated point within the feature. |
Extracts the coordinates of a point located within the feature, its bounding box, or at its center of mass, and stores them as attributes. |
Create new regularly-spaced points in a specified location. |
Create new regularly-spaced points over the extents of other features. |
Create points from every vertex of input line or area geometry. |
Chops line, arc, path, or area features into smaller features based on number of vertices or approximate length. |
Create points where features intersect. |
Computes intersections between all input features, breaking lines and polygons wherever an intersection occurs and creating nodes at those locations. |
Create points from point cloud features. |
Label lines. |
Places labels along a linear feature, angled to the orientation of each labeled segment. |
Label points at an angle. |
Replaces any geometry with a single text label at the center of its bounding box. |
Label points and areas. |
Replaces point, line, or area geometry with a single text label. |
Convert text to geometry. |
Replaces text with its location geometry, usually a point. |
Extract text properties into attributes. |
Retrieves text property values from text geometry, adding them to the feature as attributes. |
Set or modify text properties. |
Modifies or creates text geometry according to new coordinates, text string, size, or rotation values. |
Convert text to non-text geometry. |
Converts text to aggregate line or area geometry according to a specific True Type font. |
Extract point properties into attributes. |
Extracts point orientation to feature attributes. |
Set or modify point properties. |
Adds or removes point orientation. |
Geometry |
Recommended Transformer |
Example |
Point |
Line |
Area
Features with text geometry.
Features with attributes containing text property values.
Features without valid text geometry are output here.
Rejected features will have an fme_rejection_code attribute with the following value:
Text String |
Name the attribute to contain the text string. |
Text Size |
Name the attribute to contain the text size in ground units. |
Text Rotation |
Name the attribute to contain the text rotation in degrees. |
Search for all results about the TextPropertyExtractor on the FME Community.
